crud on gauges-suggestions? - Page 2 - Nissan Versa Forums
Go Back   Nissan Versa Forums > General Discussion > Detailing & Restoration
  #11
Old 01-09-2012, 08:36 PM
Default
the clear cover should be a simple replacement. it wont affect the odometer, the pcm or bcm holds onto the mileage.
  #12
Old 02-14-2012, 01:39 AM
Miguel's Avatar
Default
I don't think that can be cleaned. These gauge covers scratch or smudge very easy and anything abrasive will only further damage the clear cover. Good luck.
__________________
It is better to have lived and lost, than to listen to another record, by Olivia Newton John.
  #13
Old 03-14-2012, 02:01 PM
Default
I had a similar issue on the versa I just bought. Someone had used a cleaner that etched the plastic. I ended up using a little bit of meguiars PlastX on a cotton ball. Cleaned it right up.
  #14
Old 04-04-2012, 09:36 PM
Default
Originally Posted by athikerguy4life View Post
I just tried nail polish remover and gojo. I was trying to work my way up from least destructive to most, and while the gojo did get the gunk off, it has scratched the clear plastic. I'm just going to order a new gauge cluster and replace it. Does anybody know if this will reset my odometer readings?
Just go to an autostore and get some Turtle Wax ice total interior care spray. Works great on guages!
SEO by vBSEO 3.5.2
