for some reason I started to smell like something is burning on my V. I looked every where and nothing . I checked all fluids . I am thinking it might be leaking a small amount of oil. I notice a bit of build up on top of the motor on a holes that put oil in the motor. Any idea on how to fix or has any has had the same problem? thanks
If there is build up on the fill port, I would check the PCV system. I'm not that knowledgeable about 1st gen V, but symptoms you describe fit that of a bad PCV system. Plus a new PCV valve would be cheap.
Related Threads
115.5K posts
20.1K members
Since 2008
