New Engine at 30K - Page 10 - Nissan Versa Forums
Go Back   Nissan Versa Forums > Technical Forums > Engine Forum
  #91
Old 01-08-2012, 11:15 PM
iluvmyVersa08's Avatar
Default
BluV3R18 I listened to both your new videos ... It sounds kind of loud to me. I am pretty sure mine is much quieter. I however don't have nearly as many miles though. I should try and record mine one day to compare.
__________________
The Pampered Princess
2008 SL Sport, 17" Konig Rims, HK Exhaust, AEM CAI, UR Strut Bar, Clazzios, heated front seats, & Lots of HK :)
10 payments left
  #92
Old 02-04-2012, 09:52 PM
VinnieVersa's Avatar
Default
Originally Posted by 4DRZ View Post
Mute point. The issue is much larger than our thinly active forums. The results from here are meaningless because they dont represent a large enough number to quantify this failure rate. Spoke to a friend of mine that is a lead tech for Nissan in Texas and he lol and told me they see, on average about 3-4 Versa and cubes a week with the same issue. All for the SAME issue, and ALL piston #3.
Lol, I guess when my name comes up, most are afraid to comment?! lol j/k Dont see the point but if you guys want to....On a side note, I will keep this thread updated as I continue to dig for further clarity and answers.
With the input from all on this thread, I've got an appointment in the next few weeks to have a new 1/2 block installed under warranty on my 1.8L that has 12000 miles Thanks for the guidance. I'll report back once it is installed.
  #93
Old 02-05-2012, 12:01 AM
MajorVersa's Avatar
Default
I'm at 27k now...really hope this doesn't happen to me...well kinda actually cause ill just drop a 2.0 in
__________________
2011 Versa 1.8 HB 6Spd MT WHP: 131 WTQ:131
TAKEDA SRI
OBX HEADER/CAT DELETE
2.5" MENDREL BENT PIPING
MEGAN OE MUFFLER
NST LIGHT WEIGHT CRANK PULLEY
WHP:131 WTQ:131
NVF VotM April 2012
  #94
Old 02-05-2012, 03:51 AM
Post
You should, just to hear what she sounds like
mine does have a tick sound when is cold, but now that I'm at 100,000miles it is way too late to do anything.
__________________
2007 Nissan Versa S
MyYoutube.comVersaVideo
Average MPG 34/37
Miles per tank 340/360 10gallons per fillup
5/30 Valvoline Oil & Filter
Drive Safe & Watch for Motorcycles & Cyclists
  #95
Old 02-05-2012, 11:37 AM
Default
Originally Posted by BluV3R18 View Post
When the NISSAN dealer performed the compression test, what PSI number were they looking for, and what PSI number did it show on number 3 cylinder
on a similar issue, I had a late 90s Chevy Cavalier. they came with two engines, a 2.2L and a 2.4 engine. The 2.2L had a headgasket problem, and the 2.4L had a water pump problem. to get to the waterpump you had to remove the timing chain taking up to 8hrs on labor to replace. The factory warranty back then was 3 years or 36,000 miles
my 2.4L was overheating and the dealer said, its not overheating and I had extended warranty. The Transmisson was replaced at 80,000 and the engine started getting weaker and weaker and more overheating, did a compression test and all cyclinders were reading about 120PSI and I finally sold the car at 175,000
Back to the Versa, I did not buy extended warranty on my Versa because I was having high expectations on NISSAN but I would like to recommend to everyone to buy extended warranty. a lot can go wrong between 60,000 miles and 100,000 miles.
I do want to perform a compression test on my 1.8L but I'm really sure what PSI each cylinder is suppost to read
maybe low compression on cylinder number 3 is the root of the problem
Page EM186 indicates 217.6 psi standard and 174 psi min
http://www.nicoclub.com/FSM//versa/2011/EM.pdf
Also the Differential limit between cylinders is 15 psi
  #96
Old 02-23-2012, 04:34 PM
Default
4DRZ:
You make some valid points and data from reliable sources. Nissan just replaced my 1/2 block this week under warranty. It took a few times bring in the vehicle for the same issue and "working" with the dealership to help solve the problematic tapping. I do have to say that the tapping never went away after warming up for 20 miles. The noise was always there even after a 100 mile drive. So I believe there was a real problem with the stack up Clearances, between the Aluminum alloy piston and steel cylinder wall. Or, the block bore concentricity. Time will tell if the noise comes back.
  #97
Old 02-27-2012, 05:42 PM
Default
Yikes, this thread kinda scared me. I just bought my Versa Thursday, and she sounds like a sewing machine. I read and read all over the internets that Nissans have a tendency to sound like that. She runs smooth as silk otherwise. I'm certainly going to get everything checked while I'm still under warranty and I have the service plan that went along with my purchase. *crosses fingers*
  #98
Old 03-12-2012, 04:10 AM
4DRZ's Avatar
Default
Thanks, I am only trying to help others out. So far my wife's car is ok, however in the back of my mind I still fear the worse. I listen for every little noise now. Shouldnt have to be this way, but seems like it is. Recently on one of my other forums, a member with a brand new 2011 Maxima had a VERY similar issue in which their short block was replaced under warranty. I dunno anymore about Nissan. I have owned them since my 1st Maxima back in 1990. Sure hope we arent about to see Nissan pull a "Toyota" out of their hat.
Originally Posted by VinnieVersa View Post
4DRZ:
  #99
Old 03-12-2012, 02:32 PM
Default
You have been very helpful by laying out the facts and your experience. Our forum has a view of a tiny slice or snapshot of the bigger pitcher of this potential quality issue. In my mind, Nissan does know they have a problem as my warranty was coded as customer satisfaction. My experience has come from owning Camry’s since 1987. The 1995-1997 Camry’s were engineering super stars. One of the reasons you still see them on the road today. I’m also living through the Corolla 2009 mat/accelerator/freezing pcv “ six sigma <grin> Toyota quality.
Like you “I listen for every little noise now”
  #100
Old 03-24-2012, 05:25 AM
Default
I'm getting the noise too. I've taken it to TWO Nissan dealerships and one actually argued with me and the other simply repeated "I don't hear anything".. over, and over, and over... I'm stuck and I've just hit 40K miles. HELP!!
SEO by vBSEO 3.5.2
