Headlight not working.. relay or fuse? - Nissan Versa Forums
post #1 of 21 Old 09-07-2010, 02:20 PM Thread Starter
I have a 2009 Versa SL, and one of my head lights is having a problem. Its weird cause the DTRL works fine and the highbeams work but the low beams do not work on only the one head light. I have already tried to change the headlight bulb and that did not fix the problem.
I have looked for fuses that could be related and i looked in both boxes (the one under the drivers side dash) and the one in under the hood on the drivers side. None of them say they are related to the headlights unless i missed something? I did see one called DTRL and there is only one there and it is NOT blown.
Also i did find a small box on passenger side under the hood that contains two relays. a black one with 6pins and a blue one with 4 pins.. would these be the headlight relays?
Also does anyone have any other suggestions on what to look for or test for this?
Thanks
VersaCanada is offline
post #2 of 21 Old 09-07-2010, 06:10 PM
It's prolly a fuse.
Versa S 2009 is offline
post #3 of 21 Old 09-11-2010, 02:41 AM
promiseland's Avatar
yes, they are controlled by relays. the Body Control Module tells the relay to turn on when you turn the switch on.
If it's is just one light, it is the fuse. There is a hidden spot of relays and fuses in the engine bay. On the driver's side of the engine there is a bundle of wires going into a white box with a black cover. It's on the back of the white box.
Try this...
promiseland is offline
post #4 of 21 Old 05-06-2011, 05:02 AM
luthernil's Avatar
Hey there. I know this one has been posted last year but my issue today has something to do with this. I hope it is ok to post this one. Hope you all understand. Just got a versa 08 through a dealer's certified program with only 34k miles for under 15k. Just wondering when replacing the headlight bulb myself and use sylvania silverstars, Do i need to remove the bumper in order to pry out the headlight assembly or can I just remove the 2 10mm bolts to pry out the assemblies so that I can just reach in and replace the bulbs??
luthernil is offline
post #5 of 21 Old 05-06-2011, 08:17 AM
I was able to change mine using a small mirror. unplug the wire, undo the metal clip, pull the rubber grommet off, then bulb should practically fall off. To replace, do opposite. Just make sure to not get any oils from fingers on the bulb itself.
MuzzleNChains is offline
post #6 of 21 Old 05-06-2011, 12:10 PM
Banned
Go to the dealer. Nissan Canada recalled the DTRL relays. Problem will be fixed fast and free
jbeau is offline
post #7 of 21 Old 05-06-2011, 12:11 PM
iluvmyVersa08's Avatar
Quoted: 8 Post(s)
Is this a new recall? What model years are affected?
iluvmyVersa08 is offline
post #8 of 21 Old 05-06-2011, 12:29 PM
Banned
Fairly new. All except new 11's. You will get a letter if you are registered with nissan canada. If you are in Canada PM me your vin # and i can confirm eligibility. Or call a dealer with the vin
jbeau is offline
post #9 of 21 Old 05-06-2011, 12:31 PM
Quoted: 8 Post(s)
I haven't had any issues with my lights, but I will wait to see if I get the letter.
My Versa is registered with Nissan Canada. I received my ABS recall letter from them last summer so I know she is registered (she should be since I"m still making payments to them, lol).
Thanks for the help and info
post #10 of 21 Old 05-06-2011, 12:36 PM
Banned
no problem. 08 is definately in the recall. I had my 09 done and we do em all day long. theres a lot of versas on the road
jbeau is offline
