Help on how to replace the Serpentine Belt - Nissan Versa Forums
post #1 of 12 Old 05-19-2011, 02:37 AM Thread Starter
Miguel's Avatar
Hello,
Can someone help me on how to change the serpentine belt? I have 50k miles and while the belt still looks good, I would like to replace it for a little bit of piece of mind.
Thanks,
Miguel
Miguel is offline
post #2 of 12 Old 05-19-2011, 03:22 AM
MajorVersa's Avatar
take passenger side front tire off, undo teh front fender well lining. look right above the crank pulley and youll see the tensioner. use a 14mm wrench to rotate it towards the rear of the car and it should come right off
2011 Versa 1.8 HB 6Spd MT WHP: 131 WTQ:131
TAKEDA SRI
OBX HEADER
FLOWMASTER HFC
2.5" MENDREL BENT PIPING
IMCO V CHAMBER MUFFLER
2J RACING LIGHT WEIGHT CRANK PULLEY
NVF VotM April 2012
MajorVersa is offline
post #3 of 12 Old 05-19-2011, 02:14 PM
Quoted: 122 Post(s)
Originally Posted by Miguel View Post
Hello,
Thanks,
Miguel
I would inspect it for wear and cracks. If none there don't replace it. Especially if just replacing with a generic autoparts store belt. An OEM belt with miles on it is better then that garbage brand new. I like gates belts or whoever nissan uses for OEM myself.
any chance accessing the tensioner pulley bolt from above the car so you don't have to take the liner and wheel off?
post #4 of 12 Old 05-19-2011, 04:00 PM
MajorVersa's Avatar
unless you have tooth pick arms and hands....no....way to tight of a fit
Simon Daigle likes this.
TAKEDA SRI
OBX HEADER
FLOWMASTER HFC
NVF VotM April 2012
post #5 of 12 Old 05-19-2011, 10:24 PM Thread Starter
Miguel's Avatar
Anyone use the STP Belt Dressing stuff on the serpentine belt?
Miguel is offline
post #6 of 12 Old 05-20-2011, 01:40 AM
I suggest not to use any belt dressing. Serpentine belts work on the wedge effect of the belt and pulley. Belt dressing only causes the neoprene to swell for a short period of time. Then it is back to the squealing sound as the pulley bottoms on he belt. Unless you see cracks, or missing "v" sections and it is not squealing on startup, keep the OEM belt on as Rob suggested. .
DebbieDee is offline
post #7 of 12 Old 05-20-2011, 05:29 AM Thread Starter
Miguel's Avatar
Alright, I will leave the belt on, Thanks to anyone who helped with this question.
Miguel is offline
post #8 of 12 Old 09-29-2014, 02:44 PM
Quoted: 30 Post(s)
Let me second the "no belt dressing", that barely worked on the old belts. On new multi-rib one it can make things worse. But, that doesn't stop people from selling it.
Peacock Power is offline
post #9 of 12 Old 09-30-2014, 02:59 AM
07Versa6MT's Avatar
Quoted: 127 Post(s)
The main thing to worry about with belts is tension and structure of the belt. Perpendicular cracks in the ribs aren't a telling sign of wear anymore, it's normal tendency for the belt as it breaks in. The tensioner has a wear/stretch indicator you can see. The pivoting tensioner arm has an arrow, and it sweeps through a mark on the stationary anchor point for the spring, if it's within that mark it's up to proper tension and when it goes outside of that it has stretched and is under tensioned.
07Versa6MT is offline
post #10 of 12 Old 09-30-2014, 05:02 AM
jas32's Avatar
Quoted: 146 Post(s)
Upon request (through their website), Gates will send anyone a belt grove depth gauge to indicate if your serpentine belt needs replacing. Some people think serpentine belts do not wear out but they actually do, just very slowly.
Peacock Power likes this.
2014 Versa Note SV
jas32 is offline
