OBD-II Fault Code P0003 - Nissan Versa Forums
post #1 of 5 Old 12-31-2016, 12:26 PM Thread Starter
VinnieVersa's Avatar
My 2014 Note HB showed a code P0003 from a Scangauge which seems to be related to Fuel Volume Regulator Control Circuit Low.
NO CEL comes on and the vehicle is running fine. I cleared the code and tested it the next day. Same code P0003 came up along with B2A00 and B2AAA, which I believe these two codes are communication settings. Is there something I should be concerned about and were on the engine do I look to find the Fuel Volume Regulator Control to check to see if there are any wires broken or eaten up from mice.
Yes.. mice... I had one eat through a sparkplug wire on my snowblower down to the metal.
VinnieVersa is offline
post #2 of 5 Old 12-31-2016, 06:28 PM
BloodyChucklz's Avatar
Quoted: 18 Post(s)
P0003 DTC Fuel Volume Regulator Control Circuit Range/Performance
SOLVED: What do codes B2AAA and B2A00 mean? - Fixya
I would check the owners manual to locate the Fuel Volume Regulator Control
-= Project diVERSAfied =-
BloodyChucklz is offline
post #3 of 5 Old 01-01-2017, 12:38 PM
Quoted: 31 Post(s)
If the car is still under warranty, take it back to the dealer and let them handle it.
pimperell is online now
post #4 of 5 Old 01-02-2017, 01:17 PM Thread Starter
Yes... That is one of my options but I am over the 60K mile mark. I'll scan it again at Autozone this week and see if they see the same code.
Thanks
post #5 of 5 Old 01-10-2017, 04:33 PM Thread Starter
Thanks
Had it checked at Autozone no codes came up. I did not expect to see one as the ECM is keeping things balanced, but the negative -7 LTFT is showing a flag
I did scan it with a Go Point phone scanner and noticed the LTFT was -7 STFT was +3 and never really went to zero
Oxygen sensor voltage .28 and came up to .55v and dropped with RMP Cat temp came up to 900F but dropped back down.
So I am seeing a Rich LTFT O2 is also showing Rich being at a low voltage,
I was questioning MAF sensor.... did not move at low RPM Will look at it at higher RPM. Side note, I have been using K&N air filter which might have caused the MAF to not respond. Is the MAF sensor a film or a wire?
Am I heading in the wrong direction?
