My versa won't start - Nissan Versa Forums
post #1 of 25 Old 10-29-2013, 03:56 PM Thread Starter
Bpb
I have been googling and working on my 09 versa sl all morning and I'm getting a bit desperate! It will crank but not start up, just kinda make that whirring sound as it struggles. I tested the battery, 12.6 v jumps to 14 when it cranks. I turned on the peer while my wife listened in the gas opening and she heard the sound of the fuel pump. I've checked the fuses. Where should I go from here?
Bpb is offline
post #2 of 25 Old 10-29-2013, 04:13 PM
Quoted: 122 Post(s)
You should check the pressure in the fuel line. This could just be a failing regulator.
http://www.nissanversaforums.com/how...nking-fix.html
Fuel Pump / Fuel Pump Relay / Fuel Pressure Regulator / IPDM Trouble Shooting
post #3 of 25 Old 10-29-2013, 04:31 PM Thread Starter
Bpb
I had read up on fuel pressure regulator failure however all instances seem to result in the car eventually starting. I have had no issues with it starting and now it won't start at all despite multiple attempts today. I've searched and found no pressure regulator problems where the car didn't eventually start, am I being foolish?
Bpb is offline
post #4 of 25 Old 10-29-2013, 04:42 PM
Quoted: 122 Post(s)
I read a few where it didn't start but you are correct it isn't common. Most likely because people swap out the unit before that happens. You can check the fuel pressure to determine if it is your issue. Did you start up your car recently and move it a short distance then shut it right off? This causes me a hard start every time.
When my car wouldn't start. I would turn the key to on, wait, then off and repeat a few times trying to build up pressure in the line. I eventually had to just keep it cranking while fluttering the gas pedal and she came alive. Sometimes I would just have to walk away for a bit and let her sit.
post #5 of 25 Old 10-29-2013, 05:07 PM
08versailles's Avatar
Quoted: 53 Post(s)
Originally Posted by robj80 View Post
I eventually had to just keep it cranking while fluttering the gas pedal and she came alive..
Same here, keep trying
08versailles is offline
post #6 of 25 Old 10-29-2013, 06:13 PM
have you tried jumping the battery anyway?
I had a bad battery when I had trouble starting it
2007 HB 6spd manual Previous
2014 Nissan Sentra Current
BluV3R18 is offline
post #7 of 25 Old 10-29-2013, 09:56 PM Thread Starter
Bpb
I tried jumping and it didn't work. I eventually gave up since it's still under warranty I had them take it in and guess what it started at the shop fine. I asked about the pressure regulator and said it wasn't giving him any codes, not exactly an answer but whatever. He said he would continue to look and call me back. I haven't heard from them and it's after five so I guess I'll call tomorrow.
Bpb is offline
post #8 of 25 Old 10-29-2013, 10:16 PM
I had a car that refused to start years ago. Ended up being the car was not completely in Park. I guess I had shut the engine off before putting in Park. Also, today's cars often require the brake on when starting.
gapperguy is offline
post #9 of 25 Old 10-29-2013, 10:28 PM Thread Starter
Bpb
Someone asked me that same thing about it being in park. I took it out and into neutral and back in my troubleshooting.
Bpb is offline
post #10 of 25 Old 10-30-2013, 12:07 AM
Let the car sit for a while then get in it and turn on the ignition and wait 10 seconds before trying to start it. I have to do that with mine if it sits unused for several days.
Frank 2009 Versa S sedan MT-6 with 49500 miles
Francesco is offline
