Versa Code P0846 Solution, and Tranny fluid check - Nissan Versa Forums
post #1 of 2 Old 10-10-2014, 02:50 PM Thread Starter
Exclamation Versa Code P0846 Solution, and Tranny fluid check
Hi, I'm new to this forum. I have a 2012 Nissan Versa (CVT). My engine light recently came on, not blinking, but stays lit. I took it to AutoZone to have the code read and is reading P0846, which refers to:
Transmission Fluid Pressure Sensor/Switch "B" Circuit Range/Performance
I'm not good with cars but I work people who do work on their cars/trucks all the time, although not familiar with CVT.
They tried to check my tranny fluid as a starting point, but couldn't find a dipstick. I know that my Versa requires a special fluid which isn't a problem, but how to you change the fluid with No Dipstick?
So really what I need to know is how can I check / change the tranny fluid, and will this solve that problem and get my engine light to go off?
Any input is HIGHLY APPRECIATED! I know I could take it to the dealer, but what like to know how it is done. Thanks
Lilly is offline
post #2 of 2 Old 10-13-2014, 05:21 PM Thread Starter
Ok, so two days after this post my car died. I had it towed to the shop. They said the previous code was NOT found, but that the engine misfired, lean fuel and air. Need spark plugs replaced, reset idle air volume, reset codes. Also that brake switch tells my car its consistantly braking...?...? Tranny fluid flush and fill...$1400!!! Yowza... And my car is only 2.5 years old with 100,000 miles.
Lilly is offline
2012 versa , change transmission fluid , dipstick , no dipstick , versa
