Will 2012 Versa Rims fit my 2014 Versa - Nissan Versa Forums
 3Likes
post #1 of 11 Old 11-10-2015, 05:00 AM Thread Starter
whicky1978's Avatar
Question Will 2012 Versa Rims fit my 2014 Versa
I noticed the rims are the same size and have four wholes for lugnuts. i' m looking for the cheapest way to get a full size sparein my trunk.
whicky1978 is offline
post #2 of 11 Old 11-10-2015, 10:56 AM
D3R3K's Avatar
Quoted: 8 Post(s)
I beleive that all 2nd gen versa's have a 4x100 bolt pattern with a 59.1mm hub, so if your 2012 was a 2nd gen they should fit
D3R3K is offline
post #3 of 11 Old 11-10-2015, 02:38 PM
Super Moderator
kat_hat's Avatar
Quoted: 10 Post(s)
you can always go get wheels at Pull-a-Part oe some other type junk yard, they're super cheap. It usually isn't hard to find stuff that's still in good shape. I got a set of aluminum wheels off a B15 Sentra for my 07 Hatch. If the second gen Versa is 4x100 you'd have an easy time finding something with all the Honda's in the yards.
07 Versa S hatch 6sp.
MR20DE swap, AEM CAI, DC Sports catback exhaust, & strut bar, Racing Line lower engine mount & short throw shifter, home-made Polyurethane engine mounts, PowerFlex control arm bushings and transmission mount insert, Fortune Auto 500 coil overs, Hypercoils Springs, SL leather steering wheel, Juke Nismo shifter knob, Sparco Chrono Road drivers seat, VersaSpeed Stainless Steel brake lines, and Hawk HP Plus brake pads.
kat_hat is offline
post #4 of 11 Old 11-11-2015, 02:42 AM
jas32's Avatar
Quoted: 146 Post(s)
Bolt circle diameter is NOT THE SAME between 2012 and 2014. 2012 is 4x114. 2014 is 4X100.
Notarized likes this.
2014 Versa Note SV
jas32 is offline
post #5 of 11 Old 11-11-2015, 09:35 AM
D3R3K's Avatar
Quoted: 8 Post(s)
My 2013 is 4x100
D3R3K is offline
post #6 of 11 Old 11-12-2015, 02:34 AM Thread Starter
whicky1978's Avatar
So the honda rims fit? If the older rim has bigger bolt holes, could a part be used to make it fit snug?
post #7 of 11 Old 11-12-2015, 03:29 AM
jas32's Avatar
Quoted: 146 Post(s)
What do you mean "could a part be used to make it fit snug?" are you talking about an adapter? If so, I suppose it will fit but your offset will be out of whack. Personally I will never use a wheel adaptor on any of my cars.
I'm currently using a set of 4x100 wheels with winter tires on my 2014 Note that were previously used on a 2011 Honda Fit.
Just to clarify, 2013-2015 Versa Sedan and 2014-2015 Versa Note use the 4x100 bolt circle. Earlier Versas use 4x114.
Also, assuming you have the bolt circle issue sorted, if you are using a Honda stock wheel, make sure the hub diameter is the same or bigger than the Nissan's, otherwise you cannot use the wheel. Aftermarket wheels are usually not a problem since their hub diameter is bigger to accommodate most any car and instead use hub centric rings.
whicky1978 and Notarized like this.
2014 Versa Note SV
jas32 is offline
post #8 of 11 Old 12-10-2015, 01:29 AM Thread Starter
whicky1978's Avatar
post #9 of 11 Old 12-10-2015, 02:19 AM
Super Moderator
sergmx's Avatar
Quoted: 33 Post(s)
That almost looks thinner than OEM wheel size..i'm not completely sure though. Way too thin for my taste. But yes, it should fit your versa.
Enjoy Life.
2012 Versa HB 6-Speed.
Clean and Simple.
sergmx is offline
post #10 of 11 Old 12-10-2015, 03:45 AM
jas32's Avatar
Quoted: 146 Post(s)
NO! IT WILL NOT FIT YOUR VERSA!
Hub center diameter for the Versa is 60.1mm, Toyota Yaris hub center is 54.1
You can use the 2014 Versa wheel on the Yaris but not the Yaris wheel on the Versa.
2014 Versa Note SV
jas32 is offline
rims , spare , tire , wheels
