| Register | iTrader | Garage | gXboxLive | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Auto Escrow | Auto Loans |
| General Versa Discussion Everything about Versa's that does not fit in another forum |
#1 |
I was driving on the highway last weekend and i was forced to drive on the shoulder or get crushed by a truck that didnt see me. When i pulled onto the shoulder i ran over a shredded tire. I didnt think much of it at the time, but when i looked down at my fuel gauge a few hours later i noticed that it had went from showing a half of a tank to almost full. The gauge itself is not physically broken because it still moves up and down when i turn the car in and off. Also it goes down at the correct rate, its just at the wrong position. I filled up the other day and the needle was at full, and so far i have driven 100 miles and its still at full. Any ideas on what it could be? Thanks!
| Sponsored Links | ||
Advertisement | ||
#2 |
Super Moderator
I can't see how they are related unless you dented your fuel tank or the float, think thats how the gauge works, had become damaged from the tire. I would just run the tank out and see if the mileage is off.
There is an instrument cluster diagnostics check. I did it before. The procedure is in the FSM and basically it makes the needles move and lights on dash come on with the car not running. It was entertaining to watch. I think really it just makes sure each thing on the cluster is getting power. I don't think it re calibrates anything.
__________________
2009 Versa 1.6 sedan current mileage 124,000 44.04 mpg personal best and no I don't hypermile PM ME TO BUY FORUM DECALS |
#3 |
Good job staying in control during your "rally experience"! Glad you're okay. Welcome to NVF!
imo, sounds like a damaged and out-of-position float. I had that with a Kcar that would read 1/8th full, but it was bone dry ![]() I gotta try that instrument cluster diagnostic check!
__________________
08 Versa SL hatch 1.8 manual 213000km 2012avg41.5mpgImp. Muffler delete video http://www.youtube.com/watch?v=mIl3p...ature=youtu.be 09 Altima 2.5S cvt 128000km NEW MOTOR@90k 2012avg34.4mpgImp. http://www.nissanversaforums.com/non...09-altima.html 2001 Sentra XE manual, served me well 1972 Datsun 1200 Deluxe two door sedan manual, took a beatin' while I learned to drive Last edited by 08versailles; 06-03-2011 at 02:07 PM. |
#4 |
All the research i have done so far points to something being wrong with the float, which would make sense, since i ran the tire over on the right side of the car and could have dented the fuel tank. I was just curious of other opinions. Thanks Guys !
#5 |
The fuel gauge works by detecting resistance from the sending unit. Low resistance results in a full reading and high(er) resistance will indicate lower fuel levels.
While the sending unit may indeed be faulty, it's worth checking out the wiring leading to the tank. If the wire to (from) the sending unit got pinched and grounded, the resulting lower resistance to ground would cause the gauge to read "full".
__________________
I plan to die young, as late as possible. |
#6 |
how do i do the instrument cluster diagnostics check? i cant seem to find out how anywhere.
#7 | |
Super Moderator
__________________
| Sponsored Links | |
Advertisement | |
| Tags |
| fuel gauge, full, stuck, versa |
| Thread Tools | |
| Display Modes | |
