| General Versa Discussion Everything about Versa's that does not fit in another forum |
#1
I'm going to have to get my fuel pump replaced, as there is no way this one will go much longer. The crank times are getting ridiculous, and im afraid of hurting my starter. What is the procedure for replacing a fuel pump? Just wondering if I should clear the stuff out of my trunk (not sure where the fuel tank bolts in) or if they're just gonna be under the car. Also, has anyone had issues with them refusing service due to aftermarket parts? I have a cold air intake and a throttle controller and I don't want them to blame the part failure on that and then charge me an arm and a leg to replace. Also, what is the cost? My warranty is up and I believe there's a service bulliten out for this issue, but I'm not sure if its free or a lowered cost, or nothing. Thanks guys!
__________________
2008 Versa Sedan-AEM intake, NTD throttle controller, M2 strut brace, Whiteline adjustable sway bar, red & blue engine bay, Chinese Tiida controls, racing switch for amp, pioneer HU, 12" Boss woofer, red interior+dash lights. My Youtube Channel: The Versa Vlog! Add me www.Facebook.com/athikerguy4life |
| Sponsored Links | ||
Advertisement | ||
#2
TSB's are not the same as recalls. You will have to pay for the parts and labor if not under warranty. The fuel pump access port is under the back seat. They will not be working under the car at all.
We really need a howto on here for this fuel pressure regulator issue with part numbers and pictures. Such a common issue. Also just looked up prices. If you DIY your looking around $300 for a new pump and o-ring. I guess the regulator is part of the pump assembly so you need to replace the entire thing. I can't seem to find a part number for the regulator even though I swear I seen a post on here about it. If you have a dealer do it I bet would be 3-4 hours labor so my guess would be $700 +/- to get it all done at the dealer.
__________________
2009 Versa 1.6 sedan current mileage 88,000 44.04 mpg personal best and no I don't hypermile PM ME TO BUY FORUM DECALS Last edited by robj80; 01-25-2012 at 08:34 PM. |
#3
Fml.. that would be almost all of my tax refund. Any quick fixes? Should I just put up with it or will it just not start someday? I was really hopiing to put something fun in the car with my refund money, not just make sure it keeps working... any chance the fuel pump is covered under powertrain? I still have a year on that
__________________
#4
Yes it is covered under the 6/60k mile powertrain warranty.
http://www.nissanusa.com/pdf/techpub...2011_N_WIB.pdf
__________________
2009 Versa 1.6 sedan current mileage 88,000 44.04 mpg personal best and no I don't hypermile PM ME TO BUY FORUM DECALS |
#5
i had my fuel pressure regulator replaced after warranty. did not get whole fuel pump replaced
, just the fpr. about $50 for the part, about one hour labour at independent mechanic, not too bad. He specifically ordered just the regulator from Nissan dealer for me. I delayed replacement as long as i could by pumping gas pedal madly while cranking, but i didn't want to be stranded either so i just got it done. Hope it helps! 08v
__________________
08 Versa SL hatch 1.8 manual 160000km 2011 avg 40.6 mpg Imperial. Odometer collage:http://www.nissanversaforums.com/gen...a-have-11.html 09 Altima 2.5S cvt 90000km in the shop:( http://www.nissanversaforums.com/non...09-altima.html 2001 Sentra XE manual, served me well 1972 Datsun 1200 Deluxe two door manual, took a beatin' while I learned to drive Last edited by 08versailles; 01-25-2012 at 11:39 PM. |
#6
If its covered under powertrain warranty I'll be fine, cause I still have 1 year/15,000 miles remaining on it. PHEW!
__________________
#7
I'm searching for a car doctor [independent shop] when she starts acting up again, I will have a doctor to tow it to with tripleA roadside service. is the fuel pressure regulator inside the fuel tank or outside?
__________________
2007 Nissan Versa S MyYoutube.comVersaVideo NVF Member Since August 2010 Always on the Go! |
#9
fpr attached to fuel pump inside the fuel tank i believe
__________________
08 Versa SL hatch 1.8 manual 160000km 2011 avg 40.6 mpg Imperial. Odometer collage:http://www.nissanversaforums.com/gen...a-have-11.html 09 Altima 2.5S cvt 90000km in the shop:( http://www.nissanversaforums.com/non...09-altima.html 2001 Sentra XE manual, served me well 1972 Datsun 1200 Deluxe two door manual, took a beatin' while I learned to drive |
#10
So they shouldn't have to go in the trunk/under the hood at all right? I've heard from friends that my dealership makes a fuss with aftermarket parts. And I don't wanna get into an argument with them
__________________
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
