Nissan Versa Forums (http://www.nissanversaforums.com/forum.php)
-   General Versa Discussion (http://www.nissanversaforums.com/general-versa-discussion/)
-   -   2007 Versa--timing belt or chain? (http://www.nissanversaforums.com/general-versa-discussion/4259-2007-versa-timing-belt-chain.html)
AYang 02-14-2012 05:42 PM
Does the 2007 Versa have timing belt or timing chain?
robj80 02-14-2012 05:54 PM
Timing chain.
snowball 02-15-2012 12:16 AM
Hi Rob, or anyone else with experience on the MR18 timing chain:
Should it be replaced at some point, preferably before its breakage causes one of the pistons to smash into its valves, or is it made to last the life of the engine?
Thanks!
Cheers!
robj80 02-15-2012 02:55 AM
There is no recomended interval to change the chain.
BluV3R18 02-15-2012 05:36 AM
I'm at 100,400 miles on the same timing chain
robj80 02-15-2012 02:17 PM
You don't replace timing chains. Sometimes engines have a tensioner that can go bad and that get's replaced but I've never seen a chain stretch or break and need replacing or it being done as preventative maintenance.
The cost to replace a chain would be on par for an engine swap. It's not like a timing belt where it's easily accessible and should be done every 60, 90 or 105k miles.
Keep up on oil changes and enjoy your maintenance free, but slightly noisy compared to a belt, timing chain driven car.
JoshG 02-15-2012 04:54 PM
Is the 1.6 chain as well? Or is it a belt?
robj80 02-15-2012 04:59 PM
also a chain
JoshG 02-15-2012 05:04 PM
Sweet, one less thing to worry about...the belt in my old car went out and replacing it was a PITA!
BluV3R18 02-16-2012 04:39 AM
I hear ya... I don't like it when they remind me the timing belt is past due :cryin:
I did have a 2.4 cavalier and the tensioner had to be replaced because it went down south and sometimes when I started the car the timing chain made noise because it was rubbing against the timing chain cover
I think the best way to keep the timing chain running good is keeping it well lubricated just like a bicycle chain, and the best way to keep the timing chain lubricated is... Change the oil :thumb2:
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
