rough idle at stop lights. - Nissan Versa Forums
post #1 of 17 Old 04-28-2013, 08:22 AM Thread Starter
Hi Versa owners!
I drive Versa 2010,1.8L.Recently I've noticed rough idle that comes while stopping in drive at stops.Can anyone offer some help?
tonya is offline
post #2 of 17 Old 04-28-2013, 12:57 PM
JVersa's Avatar
Where do you feel the vibration from?
TEIN Springs.
Takeda Short Ram Intake.
DC Sports Cat-Back Exhaust.
DC Sports Strut Tower Brace.
JVersa is offline
post #3 of 17 Old 04-29-2013, 12:03 AM Thread Starter
Vibration comes from engine.RPM up and down.
tonya is offline
post #4 of 17 Old 04-29-2013, 01:21 AM
JVersa's Avatar
How many miles, and do you drive it hard? If miles are high the mounts might be bad, if low and you drive it hard same thing. Beyond that, could be fuel injection is not off or objectors them selfs, even a problem with your cams, I would take it somewhere to diagnose the problem, most shops do that much for free.
TEIN Springs.
JVersa is offline
post #5 of 17 Old 04-29-2013, 07:46 AM Thread Starter
87000km on it,don't drive hard.On "N" and "P" the idle is ok,no vibration at all.Only on "D" with brake pedal applied.
tonya is offline
post #6 of 17 Old 04-29-2013, 09:19 AM
AusTiida's Avatar
Is it 'hunting'? Or is it a stable RPM and vibrating? Is it the engine vibrating or the gearbox? Have you checked all of your oils?
Have you had the spark plugs replaced yet? Although the plugs are supposed to last 100,000km, Mine had to be replaced around 85,000 as it was running pretty poorly and at one stage shuddered off the line and threw a 'check engine' light.
A couple of things to check and mark off the list
AusTiida is offline
post #7 of 17 Old 04-30-2013, 05:33 AM Thread Starter
Like I sad RPM is not stable,that's why I can feel vibration from engine.Oils are ok.Plugs are changed at 80 000km.Thanks guys for quick reply!
tonya is offline
post #8 of 17 Old 05-01-2013, 12:28 AM
VinnieVersa's Avatar
OK... give us RPM swing you are seeing at idle. ( in drive and in neutral) I've seen the vibration coming from the hood that was setup by a frequency of the engine. Move the rubber grommets and the vibration went away. Let us know what your RPM swing is
VinnieVersa is offline
post #9 of 17 Old 05-01-2013, 03:55 AM
Quoted: 33 Post(s)
Dirty injectors, dirty fuel filter, dirty egr, pcv valve, failing o2 sensors, vacuum leak....
Versa12 is offline
post #10 of 17 Old 05-01-2013, 04:47 AM
AusTiida's Avatar
^^ too true, it's going to be a task of elimination to work out what's going on. Did you suddenly notice it? If so, can you recall when, and what did you do to your Versa before this happened?
AusTiida is offline
