How to: Reset TPMS light - Nissan Versa Forums
post #1 of 1 Old 09-25-2013, 03:06 PM Thread Starter
I recently had new wheels and tires fitted on my V. While it was in the shop one of the technicians broke a tire sensor. They ordered a new one and installed it for me a few weeks later. When I picked up the car they told me they were unable to reset the TPMS light since their scan tool didn't work on Nissans. They told me I'd have to take it into a dealer and get it reset then I could bring them the receipt for reimbursement. That's great and all except that I'm in the middle of nowhere and the closest Nissan dealer is 70 miles away. I found a procedure on the myG37.com forum posted by Modme. I decided to give it a try on the V and it worked!
Tools required: A piece of wire (paper clip, safety pin, etc.),
tire gauge (preferably digital) , and an air compressor.
Step 1 setting tire pressures: You have to be precise on this step!
Front Left: 34 psi Front Right: 31 psi
Left Rear: 26 psi Right Rear: 29 psi
Step 2 Find the TPMS interface plug. The following steps aren't completely necessary but they make it much easier to get to. Remove the plastic panel under the steering wheel. There are Phillips 2 screws located behind the fuse panel cover. Remove those and it should pop right off. After that you can remove the 3 screws that attach the dimmer/mirror controls to the panel. Then remove the single screw that holds the OBDII port in place.
The plug is located (at least mine was) right behind the fuse panel coiled up and taped to the OBDII sensor harness with a single piece of electrical tape. The area is right above where your left knee would be while sitting in the seat. It is a small white plug with a single white wire running to it. It shouldn't have anything plugged into it.
Step 3 stick your paper clip, wire, or safety pin into the plug. Make sure it has contact with the metal pin inside the plug It was easier for me to get contact by probing the rear of the plug since my wire was to large to go in the front.
Step 4 reach up and turn the key to the KOEO or ignition position. (don't start the car)
Step 5 tap the end of the wire 6 times on a grounded piece of metal. The steering column bracket is a perfect place to ground the wire. Tap relatively slowly and hold the wire to the metal long enough to ensure your making good contact. (don't worry it won't spark there is little or no current in this wire)
Step 6 If you did step 5 correctly your TPMS light should start flashing slowly. You are now in relearn mode!
Note: If the light doesn't start flashing you didn't do it right! Turn the key off, then back on and try again. The light should start to blink almost immediately after your 6th tap
Step 7 Drive the car around for 5-10 min at 25+ mph the light should come on solid for 15-30 seconds then go out for 15-30 seconds. After the light goes out it'll come back on letting you know you have a low tire (remember Step 1?)
Step 8 Air your tires back up to 35+ psi, the TPMS light should now be off. Congrats you just saved yourself $90!
BlackVsedan is offline
