How To: Remove 1st gen. Versa Steering Wheel - Nissan Versa Forums
post #1 of 36 Old 03-13-2011, 05:57 PM Thread Starter
1) Make sure wheels are straight. Unplug the battery, and wait about 10mins.
2) On the back of the steering wheel are these caps. Take them off with your fingers or flat head.
3) Take the flat head and put it into the holes and push hard straight. It will feel like a type of spring. Take your other hand and feel for the airbag to move forward while pulling up slightly. Do this for both sides. Once released, take your hand and gently pull up on the airbag, It may feel still stuck, just pull a little harder.
4) Once removed, a yellow, orange, and green wire will be connected to it. Try to keep the airbag away from your body and face as much as you can while working on it. The green is for the horn, and the orange and yellow are airbag. Disconnect the green wire by just pulling it straight off. Now for the airbag wires. While holding the airbag in your one hand, take a pair of pliers and squeeze them on the black piece and pull straight up. Do this for both. The airbag is now freed. Place the airbag upright somewhere away from you.
5) Now is the cruise/audio connector. Just unplug that connector. I found the next step to be useful putting the steering wheel into it's locked position. Unscrew the bolt in the middle with a socket wrench, and remove the bolt. Now you can just simply wiggle the wheel back and forth, and the wheel will just pop off.
6) Replace with the new steering wheel and reverse the directions.
7) Enjoy!!
NOTE: This is for 1st gen. Versa. The difference between the 07-08 and 09-11, is the buttons are illuminated in 09-11 and needs two extra wires. But other then that it's all plug in play and the 07-08 steering wheels can be mounted anyways even without the extra two wires and still keep the cruise function. I wouldn't doubt it's reversible too! I transferred my cruise buttons so I keep the illuminated buttons. This was alot easier than I expected.
tiidaireland likes this.
Versa S 2009 is offline
post #2 of 36 Old 03-14-2011, 04:59 AM
flversa's Avatar
does your airbag light turn on though after unpluging the airbag though
Project "UNIQUE"
flversa is offline
post #3 of 36 Old 03-14-2011, 05:26 AM
those are good instructions!
BluV3R18 is offline
post #4 of 36 Old 03-14-2011, 02:35 PM Thread Starter
No, cause the battery was disconnected and I waited about 10mins before doing any work, so basically the car doesn't know the airbag was removed, so it's all good.
post #5 of 36 Old 03-15-2011, 01:36 AM
Quick Question
I noticed the steering wheel before didn't have radio controls. Did the new wheel audio controls work or did you have to run any wires? And do you know if you can just get the audio controls and put them on the steering wheel?
THanks for your help
caraudioguy is offline
post #6 of 36 Old 03-15-2011, 01:55 AM
Originally Posted by Versa S 2009 View Post
No, cause the battery and fuse is disconnected and I wait about 20mins before doing any work, so basically the car doesn't know the airbag was removed, so it's all good.
hi i have a 09 v hatch and i do not have the cruise control package but is my car pre wired ? so that i just have to buy a sterring wheel with the buttons and just plug and play ?
stamantm1 is offline
post #7 of 36 Old 03-15-2011, 10:48 AM Thread Starter
Thanks for your help
From my understanding the 07-08 are more then likely to be pre-wired for audio controls. Starting in 09 they are not. Mine is an 09 and comparing the plug from the old and new steering wheel they are the same, and the wires that where missing in the old plug I took out of the new plug and popped them into the old plug. Now the plug is full of wires and plugged right in the clock spring. The wiring is my next step. Haven't done it yet. It looks like the clock spring has it together, and I think I know where the wires come out of the clock spring and to the radio, but I waiting for confirmation to know that's the right plug. As far as just the buttons, most people are selling the whole wheel cause the cruise and audio connections are on one plug and you would have to cut the wires. So they sell the whole wheel instead. Plus it's leather wrapped too!! I got mine for $100.
post #8 of 36 Old 03-15-2011, 10:51 AM Thread Starter
I will say this. I am more than positive the steering wheel area and clock spring is wired and ready to go for the buttons, but I don't know if it's wired from the clock spring to the car. Do you have the power package?
post #9 of 36 Old 03-15-2011, 07:43 PM
Can I ask where you found yours? I have been looking for awhile now. I talked to the dealer and they said the have the curise bluetooth combo swtich for 100. But of course I have to order it to see if it is the right part. Thanks for the quick response and your help...
post #10 of 36 Old 03-15-2011, 08:25 PM Thread Starter
Well I checked ebay everyday for like 2 weeks, and finally one showed up for 3 days only. I was the only bidder and I got it. The plus is I contacted bob from versaspeed and hes gonna give me the wiring diagram so I can wire up the buttons. No matter what year you buy, they will all be plug and play, the only difference is the 07-08 are not illuminated. Mines not illuminated, but the cruise is, cause I popped the wires out of the new plug, and placed them in my old plug so I could keep my illuminated cruise buttons.
