How-To: Replace the Alternator on a '07 Versa - Nissan Versa Forums
post #1 of 11 Old 09-22-2011, 11:48 PM Thread Starter
MeVersaTheWorld's Avatar
What's going on Versa peeps!
My girlfriend owns a Versa as well but it's a sedan model instead of the hatch. Oh and it has about 120,000 miles on it. Pretty insane considering she owned it for just 5 years! With this many miles saddled on any car, things are bound to go bad; sure enough, her alternator died the other day. Naturally I was called into duty to fix her ride
So here is the procedure for replacing the alternator on a '07 Versa. It probably applies to other model years and the hatchback model too
Where is the alternator located relative to the engine?
1) Disconnect the battery cable from the negative terminal.
2) Remove drive belt.
3) Disconnect alternator connector.
4) Remove “B” terminal nut. Be sure to tighten “B” terminal nut carefully.
5) Remove alternator bolts.
*diagrams courtesy of nissanpartszone
6) Remove alternator assembly from the vehicle.
To install:
1) Installation is in the reverse order of removal.
Good luck guys!
Hopelessly addicted to Versas since 2007!
MeVersaTheWorld is offline
post #2 of 11 Old 09-23-2011, 12:04 AM
Miguel's Avatar
What size socket are those bolts?
It is better to have lived and lost, than to listen to another record, by Olivia Newton John.
Miguel is offline
post #3 of 11 Old 09-23-2011, 05:30 AM
looks pretty simple... The location is what makes me wonder how long it would take to replace and how difficult it would be to get it removed.
I'm at 91,000 miles, did it show any warning signs the alternator was going bad?
slow wiper blades, dimmer dashlights and headlights or anything else?
or just didn't start and battery was dead?
2007 HB 6spd manual Previous
2014 Nissan Sentra Current
BluV3R18 is offline
post #4 of 11 Old 10-18-2011, 05:18 AM
reinaldo's Avatar
replace alternator
Thanks for sharing this very detaild step. Most people are having troubles removing and installing the alternator properly.
reinaldo is offline
post #5 of 11 Old 10-18-2011, 01:24 PM
Thanks for taking the time to write this. No offense to you or anyone else that has been doing these copy pastes of the factory service manual "how to's" but in this section it would be more helpful to the DIYer to have actual pics of the experience. Also include the tools needed. Maybe even belt part numbers since it would be a common thing to change while doing this. There is a tensioner pulley that must be loosened and moved in order to "remove drive belt" as you say in step two. But no mention of how to do this or it's location.
I think this is a good start to a how to but is lacking a little bit of into.
post #6 of 11 Old 10-19-2011, 12:25 AM
bboy_romeo's Avatar
I second that
- 6000k Bi-Xenon HID's, Custom Catback w/ Magnaflow muffler, AEM CAI, Tanabe SUSTEC NF210 Lowering Springs, Tanabe Strut Tower Brace, Ultra Racing Rear Shock Tower Brace, 17" Konig x906 Black Wheels w/ Falken tires 205/45/17, JVC KD-R208 deck w/ Kenwood amp and 10" Energy Sub, blue interior painted, 3 piece mesh grille, debaged, tinted tails, versa 3rd brake light decal, vortex roof spikes, window visors etc..
bboy_romeo is offline
post #7 of 11 Old 10-20-2011, 09:06 PM
I would delete this whole post because this is not a how too. What the poster dosent mention is how to know when ur alternator is going out and how to properly replace it. As seeing as I am probably the only one to have done it, I can tell u the whole post is wrong
bigdaddychia is offline
post #8 of 11 Old 12-22-2012, 03:26 PM
Bobjeeps
Alternator, Replace
bobjeeps is offline
post #9 of 11 Old 12-22-2012, 03:34 PM
Nissan versa 07 alternator replacement
Alternator, Replace
Vehicle: 2007 Nissan Versa SL 1.8 L4 GAS
Remove front passenger wheel. To the right of the shock/spring housing you'll see two plastic pins. This holds the splash shield in place, remove them & open the splash shield. Using a 14mm wrench, put it at about 4 o'clock on the spring tensioner arm & pull down. This relives tension on the belt, slide the belt off the wheel that's to the right of tensioner. Go under the hood, using a 10mm socket disconnect neg side of terminal on the battery. These other steps are to allow room to work & space to remove alternator. Next remove the 2 bolts on the nissan plastic engine cover housing & the engine cover housing BRACKET that's located at the front LEFT corner of the valve cover. Unbolt ground strap that's located on the cars frame right behind the left headlight, in addition left to ground bolt, unbolt the bracket that supports the a/c line. Remove radiator reservoir tank, disconnect belt & wires from the alt. The two 13mm bolts on the alt use a wrench. When loosen then use a 1/4 ratchet with a 13mm socket. Slide bolts out as FAR as possible. Now you should be able to wiggle out alt & bolts as one piece. I had to use a long screw driver/bar to dislodge alt. Install in reverse order. Total time took me about an hour.
bobjeeps is offline
post #10 of 11 Old 02-17-2013, 12:00 AM
#5 Their is no way you can remove bolts, that hold the alternator as stated. They are unbolted and removed with the alternator as one unit.
bobjeeps is offline
