Originally Posted by luxman
I know my reply is a bit too late, but depending on the amp's size, you can go under the front seats. Good thing is that you will run less wires and the amp will not take any space in your trunk. Just one thing: be sure to put it in something that will protect it from being kicked by other guys shoes... And protect it from water and ice.
I did this with an Alpine amp, it is installed under the passenger seat. I'll send you pictures of it.
Installing an amp on a subwoofer box never been a good idea... Imagine yourself trying to get the spare tire with all the wiring going to the box that can't be removed fast enough....
totally agree! i'm currently working on installing an amp and installing it under the passenger seat. if your amp is slim enough, one should try to mount it on a board and then bracket the board down. under the seat is usually one of the lowest floor points in the cabin and you're certainly right about protecting it from your friends kicking it or getting any moisture on it.
another idea would be in addition to mounting the amp under the seat, would be making a port panel in the trunk. using 1/4" TRS ports mounted into one of the side panels, one could make one or 2 1/4" TRS (think guitar cable, or 1/4" headphones type plug) plug cables to easily plug in or remove when needing to pull out a sub box.
