| I.C.E. - In Car Entertainment Discuss about audio, video, navigation, security and wiring here |
#1
Hi!
I want some bass in my versa, versus none. Just want a basic setup--monochannel amp, 10" sub. However, I want to keep my cargo space. There are some seriously shallow-mount subwoofers & box ("loaded enclosure") combos available, but that still leaves me with where to put an amp. Just bolt the amp to the back of the box? Or is there anywhere in this car to hide it? Maybe under the front seat, and run the speaker cables back under the trim to the sub... And velcro the box to the carpet/seatback, so I can remove it when I need to lay the seats flat for cargo? Where do you have your cables pop out of, to be the most concealed? Only done one audio setup before, and that was in an old wagon-- I hid the entire box under the rear cargo hatch, there was so much excess space. The versa will be trickier. |
| Sponsored Links | ||
Advertisement | ||
#2
![]() I've had my amp screwed to the box for years, no issues I think I'm gonna cut it down by a third and mount it on its end to take up less space. My cables will again be tucked under the door jamb, out of sight. Power wire will enter firewall thru grommet beside the clutch pedal here
__________________
08 Versa SL hatch 1.8 manual 171000km April avg 40.2 mpg Imp, 7.0L/100km[thx TDIclub!]. Exhaust video http://www.youtube.com/watch?v=mIl3p...ature=youtu.be 09 Altima 2.5S cvt 96000km NEW MOTOR http://www.nissanversaforums.com/non...09-altima.html 2001 Sentra XE manual, served me well 1972 Datsun 1200 Deluxe two door manual, took a beatin' while I learned to drive |
#3
I would install the amp on the back of the subwoofer box
__________________
2007 Nissan Versa S MyYoutube.comVersaVideo Average MPG 34/37 Miles per tank 340/360 10gallons per fillup 5/30 Valvoline Oil & Filter Drive Safe & Watch for Motorcycles & Cyclists |
#4
oh man if only i could show you the setup one of my friend's friend has in his VW that would work so perfect for you. He has an amp mounted on the back of his seats and has a 10" sub in a slim box that can easily be fitted somewhere so you can have all the space you would have originally in your v.
here is something similar, maybe even the same one he has! I betcha this will work well for you hope this helpsPioneer 10" Slim Subwoofer System (TS-SWX251) : 10" Subwoofers - Best Buy Canada oh and btw.. this thing sounds great! probably exactly like mine (and mine is a 10" in a huge box lol) but again gives you the benefit of not sacrificing space
__________________
- 6000k Bi-Xenon HID's, Custom Catback w/ Magnaflow muffler, AEM CAI, Tanabe SUSTEC NF210 Lowering Springs, Tanabe Strut Tower Brace, Ultra Racing Rear Shock Tower Brace, 17" Konig x906 Black Wheels w/ Falken tires 205/45/17, JVC KD-R208 deck w/ Kenwood amp and 10" Energy Sub, blue interior painted, 3 piece mesh grille, debaged, tinted tails, versa 3rd brake light decal, vortex roof spikes, window visors etc.. |
#5
If you just want "some" bass why not just replace the stock speakers with ones with higher wattage ones with a lower low-end frequency response?
__________________
2008 Versa 1.8 SL CVT Hatchback (keyless, bluetooth, spoiler, 2010 grille), DC Sports Front Strut bar, AEM CAI, Ultra Racing Rear Sway Bar. |
#6
Bboy_Romeo, how did he go about mounting the amp into the seat?
I've only taken apart one seat back, once, on a volvo. I remember springs in front, foam throughout, and retaining clips everywhere to hold the cover on taut. I suppose... there *might* be room to hide an amp completely inside the seat? Use sheet metal and sheet metal screws to make a bracket for it? It's something i was thinking of. Or if there's even room in the cushion. I'd really have to find a small amp and take apart the seat to be sure! Or talk to the nissan service department to see if someone's already had one apart and know what it looks like on the inside ![]() Better speakers... do they make small speakers that put out good bass these days? I'm not "into" audio and don't know what's out there. I just know that the 4 and 5" speakers on my old car had *no* bass. I just assumed you needed a large speaker, to move the amount of air that bass requires? |
#7
sorry no idea how he mounted it, i only had a quick look at his setup. but i would think a slim sub and mounting your amp somewhere would be ideal for you. why not take a look at other v owner's profiles/ picture galleries and see how some others have mounted their amps or just in general of how they have their setup, that could help!
__________________
#8
on rear seats there is usually a hard backing that you can screw into to mount an amp. The amp doesn't go inside the seat, it is just screwed into it.
__________________
2008 Versa S Sedan-Intake, ETC, Strut brace+Sway bar, Spec-V wheels, OEM Fogs, Pioneer+Boss Audio. My Youtube Channel: The Versa Vlog! |
#9
Here is a 30hz signal for perspective. If all you're hearing is static distortion then your speakers don't go low enough. My headphones (Beats by dre studio) go pretty low, if you have a sub on your machine should go low too. Anyway I say replacing stock speaker should be step 1 before head unit or sub. I am totally satisfied with were I am at right now after spending less than $150 total on front and rear speakers.
__________________
#10
I know my reply is a bit too late, but depending on the amp's size, you can go under the front seats. Good thing is that you will run less wires and the amp will not take any space in your trunk. Just one thing: be sure to put it in something that will protect it from being kicked by other guys shoes... And protect it from water and ice.
I did this with an Alpine amp, it is installed under the passenger seat. I'll send you pictures of it. Installing an amp on a subwoofer box never been a good idea... Imagine yourself trying to get the spare tire with all the wiring going to the box that can't be removed fast enough....
__________________
AS FAST AS MOLASSES TRYING TO CLIMB A HILL IN WINTER... Versa 2007 sedan --- ALX Wheels, Eibach coils, DC Sports strut bar, WeaponR cold air, Ram Air Kit, Banbo HID, Magnaflow muffler, Pirelli tires, Pioneer deck, Kenwood eq and subs, Orion amps and subs, Paradigm mid-bass, Piaa fog, Sirius, Alpine amp, Audiovox lcd sreens, Viper remote start and alarm, Prosport meters, Ractive |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
