Sub & Amp Setup - Nissan Versa Forums
Go Back   Nissan Versa Forums > Technical Forums > I.C.E. - In Car Entertainment
  #1
Old 11-28-2011, 04:19 PM
Default Sub & Amp Setup
This is my first post on versa forums and I was looking for some input on my system. So far I have my stock head-unit w/ stock speakers. I have a "1400W Class A/B 2-Channel PZT Power Zone Series Stereo Car Amplifier" along with a 12 inch G1 Boston sub. I would like some input on the quality of the amp/sub and what anyone would suggest for a head-unit and speakers. I have found out the hard way that not all head-units fit in my versa.
  #2
Old 11-28-2011, 05:39 PM
athikerguy4life's Avatar
Default
I've never heard of PZT, but if the sub is boston acoustics, then its probably pretty good. I've never tried them, but they are supposed to be really good for sound quality. Most HU's will fit in the vera opening since it has standard double-din sized opening. Check out crutchfield.com or Sonicelectronix.com for good deals.
__________________
  #3
Old 11-28-2011, 06:31 PM
Default
My amp is actually a Crunch PZT1400. I copied the wrong information in my previous post.
  #4
Old 11-28-2011, 11:29 PM
Default
gotcha. crunch isn't too bad. whats the fuse rating on the amp?
On another note, does the "redsox" name imply that you are from the northeast?
__________________
  #5
Old 11-29-2011, 02:16 AM
Default
Fuse Rating: 30A x 2
Yes i am from the northeast
  #6
Old 11-29-2011, 03:19 PM
Default
The amp should put out plenty of power. You have to be careful cause sometimes the "low end" brands will advertize 3000 watts but they have tiny fuse, so you know they aren't capable of the power. Just remember that the versa only has a 110 amp alternator, and thats a cruising speeds. at idle you aren't making nearly that much power and you could have trouble with headlight dimming and such if you really crank it.
__________________
amp, speaker, stereo, subwoofer
SEO by vBSEO 3.5.2
