| I.C.E. - In Car Entertainment Discuss about audio, video, navigation, security and wiring here |
#1
I have 2010 sedan nissan versa, and bought a direct hard wire for my beltronics radar, were can I tap in the drivers fuse box area under the steering wheel that is something that it on when key is turned to on position or car is running?
Thanks |
| Sponsored Links | ||
Advertisement | ||
#2
There should be a free slot under acc section to the left of the acc port fuse.
Just look at the diagram.
__________________
2008 Versa 1.8 SL CVT Hatchback (keyless, bluetooth, spoiler, 2010 grille), DC Sports Front Strut bar, AEM CAI, Ultra Racing Rear Sway Bar. |
#3
Havnt looked for extra power inlets let me know what you find.
__________________
11 nissan versa 5dr. 1.8L MT |
#4
I've done it before to wire my under dash lighting and I will be doing it again for my GPS. There is a free outlet in there, there is a diagram on the inside of the door to the fuse area. Very very simple stuff.
__________________
#5
I saw the diagram just was confused which one I was to use do you know which one? pic?
__________________
2010 Nissan Versa 1.8 S upgrades: OEM 15" Alloy wheels, SL console, 20% Tint, |
#6
Ummm, on mine it's on the lower right on the diagram, with ACC.
__________________
#7
This is a picture of my area were I should tap for radar, can someone point to were exactly I should tap? Doesn't it need to be the ign? since it turns on when car is turned on and then turns off.
__________________
#8
The one directly to the left (on the diagram) of where fit says 15A Power Socket should do the trick.
That will make it turn on when you turn the key to 1, 2, or ignition. I have my under dash lighting positive wire on a fuse tap there, and the ground wire going to the screw on the rim of the fuse box (black screw right behind the door.) Only the one on the right is connected to metal and grounds it, left doesn't work. You could also tap between Washer Motor and Eng Control (though on mine that slot doesn't seem to work) or just use an add-a-circuit tap that lets you keep the original fuse intact and go in on something non-critical on ignition (like washer motor.)
__________________
2008 Versa 1.8 SL CVT Hatchback (keyless, bluetooth, spoiler, 2010 grille), DC Sports Front Strut bar, AEM CAI, Ultra Racing Rear Sway Bar. Last edited by Ben_B; 12-21-2011 at 12:42 AM. |
#9
thanks for help. I will see what I can do.
__________________
#10
Ok I was able to install it works like a charm, thanks guys for all you help.
__________________
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
