1st Gen Altima Wheels on a Versa? - Nissan Versa Forums
 5Likes
post #1 of 15 Old 10-08-2014, 03:06 AM Thread Starter
Quoted: 26 Post(s)
Question 1st Gen Altima Wheels on a Versa?
I am wondering if anyone has knowledge or experience on the fitment of mid to late 1990's Altima wheels on a Versa. I am interested in maybe swapping my steelies for OEM 15x6 aluminum wheels. I find them cheap on CL, but they usually need to refinished. My question for you is, are they a perfect fit? I ask because I see posts referring to Sentra Spec V wheels needing a shim. I have not been able to find much about old 15" or 16" wheels though.
2014 Versa Note SV
trick is offline
post #2 of 15 Old 10-08-2014, 01:11 PM
Quoted: 30 Post(s)
According to Tirerack.com the Altima uses a 4 x 114 bolt pattern, we use a 4 x 100 bolt pattern.
2014 Versa Note SV w/Convenience & Sport Value Pack
Peacock Power is offline
post #3 of 15 Old 10-08-2014, 01:38 PM
They work great on older Versa's with the smaller breaks like my car.
but like stated above they are 4x114 and newer Versa's and Notes use 4x100.
JoshG and Peacock Power like this.
post #4 of 15 Old 10-08-2014, 02:04 PM
jas32's Avatar
Quoted: 151 Post(s)
Yes, PP is correct. The newer (13-14-15) Versa Sedans and all Notes are 4x100mm bolt pattern. Earlier this year when I was shopping for my wheels, even TireRack had the bolt pattern wrong. They've since had it corrected.
Also its very important to note that the bore diameter for the VSedan and Note is 60.5mm, so an OEM Honda Fit or Toyota 4x100mm wheel will also not work since these are usually smaller bores.
Aftermarket wheels should be fine since they have bore diameters that are usually larger than 60.5mm. You will just have to use the appropriate hub ring adapter for hub centric mount, if you so desire.
Peacock Power likes this.
2014 Versa Note SV
jas32 is offline
post #5 of 15 Old 10-08-2014, 02:19 PM
Older Nissan's had 4x100. You may want to look into some b14 SE-R wheels
post #6 of 15 Old 10-08-2014, 07:45 PM
NecosNote's Avatar
Quoted: 79 Post(s)
Use Honda stock wheels, cheap and all over
NecosNote is offline
post #7 of 15 Old 10-08-2014, 09:06 PM
Quoted: 30 Post(s)
Don't you have to watch out for bore center being under-sized and the wheel not fitting without machining?
post #8 of 15 Old 10-09-2014, 02:38 AM
jas32's Avatar
Quoted: 151 Post(s)
Not going to work Necos.
As I said on a previous post, bore center is too small on a Honda (56mm). Note requires 60.1mm (sorry I think I said 60.5 on a previous post).
I just bought an aftermarket set of wheels (for my snow tires) which were previously used on a Honda Fit and I had to look for new hub centric rings.
2014 Versa Note SV
jas32 is offline
post #9 of 15 Old 10-09-2014, 03:17 PM
Quoted: 30 Post(s)
Jas32, How are you going to deal with TPMS issue? I haven't decided if I'm getting winter tires/wheels for the car and that's an issue that will sway my decision.
post #10 of 15 Old 10-09-2014, 03:21 PM
NecosNote's Avatar
Quoted: 79 Post(s)
This is correct I didnt even think about this, I retract my statement
