Hardware for control arm/ball joint and upper link replacment? - Page 2 - Nissan Versa Forums
post #11 of 13 Old 11-22-2018, 12:32 AM
Quoted: 90 Post(s)
You got it right on the numbers being the various ways to express torque.
amc49 is online now
post #12 of 13 Old 11-23-2018, 01:37 PM
Just to clarify my ramblings.
The horizontal bolt that connects the lower control arm to the sub-frame "119(12,88)" is the one where you either have to jack up the engine or lower the sub-frame to get it out.
The lower bolt on #12 (linkage) can be problem in the rust belt, the fuses into the #12 part. This is only a problem if you need to replace this part. Other wise, If you choose to lower the frame, just remove the upper bolt on #12 and leave the bottom one alone.
scarecrowdjinn is offline
post #13 of 13 Old 11-24-2018, 05:50 PM Thread Starter
Thanks, I understand now!
I have succeeded in my replacement of the control arm. I didn't bother with the vertical in the end (though I might yet go back to it particularly if they tell me that they still can't do the wheel alignment for any reason). Two things I discovered:
- as I mentioned, with the six-speed manual, the troublesome horizontal pivot bolt is a non-issue. There's nothing in the way
- I got hold of the workshop manual that scarecrowdjinn had shown a picture from and discovered that the white cross on a black circle background (the one that looks like a philips/crosshead screw) that shows up in the image means "do not reuse this part". So, I'll be putting a new nut on that vertically oriented pivot bolt fairly soon
Other than that, guess what? All the experience I got on the left side will soon get practiced on the right side. I took it in for alignment after finishing the left side, and they told me the ball joint on the right side is shot too (just nowhere near as badly/obviously as the one on the left, for which the arm itself was also bent about 20 degrees!)
Anyway, many thanks again for all the help, encouragement, and explanations!
Simon Roberts is offline
bolt , control arm , hardware
