Nissan Versa Tensioner Pulley Issue - Nissan Versa Forums
post #1 of 12 Old 04-16-2014, 01:04 PM Thread Starter
go7roo7's Avatar
Hey guys/girls.
My fiancee has a 09 Versa 1.8L hatchback auto.
She has been noticing vibrations coming out of the engine bay that she can feel in the cabin ( noise) and vibration in the pedals. Her car has about 69k on the clock. Said vibrations are not really shown in park or neutral or reverse, only drive, and only after the car has been on the road for a while.
I took some time from working on the Z to check out her car and see what may be going on. This is what I found.
* After her accident about a year ago, the body shop did a piss poor job at putting her intake back together so it vibrates like all hell. This also happened
* Her tensioner pulley and or the entire tensioner assembly seems to be bad. ( you can see in the videos)
* In the last video, while the car is in drive ( and ebrake on for my safety) you can see how I cause changes in the vibrations on parts in the engine compartment. This was last night so I will have to start taking things apart to see what is most likely rubbing.
* I have not done a compression check to see if the motor is fine ( yet) But some people on the Nissan forums said it might be belt slap I am hearing, but to me it does not seem that way.
My questions are:
A: The FSM calls for a 50 Torx to be used to remove the entire tensioner pulley assembly but all of my 50Trx
tools are too large to fit in the space ( watch the video to see the crappy clearance)
What tool can I use with a size 50 Torx bit and have enough leverage to take this guy out?
B: Per the video, would you guys conclude as well that the tensioner needs replacing? ( I like redundancy)
C: What else do you guys think might be wrong?
Here is the pic of the FSM diagram
Here is a side pic of where the pulley is
Now the videos
https://www.youtube.com/watch?v=ypvPAFgGUfA
https://www.youtube.com/watch?v=k7Vd0Skxus8
( DO NOT DO WHAT I DID ;D)
https://www.youtube.com/watch?v=D_KatEOItZw
You can see me making the noise here with the plastic intake.
https://www.youtube.com/watch?v=f2LqLHlpMos
go7roo7 is offline
post #2 of 12 Old 04-16-2014, 03:51 PM
08versailles's Avatar
Quoted: 53 Post(s)
It's been reported when plastic floppy intake is replaced with after market or custom job, one certain vibe disappears. Likely the one you describe. Try a temporary removal to troubleshoot. I'm not a mechanic, but hope it helps
08versailles is offline
post #3 of 12 Old 04-16-2014, 07:51 PM Thread Starter
go7roo7's Avatar
Thanks, this is what I was going to do. Upon closer inspection it seems some of the foam trim used to seal each individual part of the stock intake has come off. Sounds like I will have to make a trip to home depot to buy some stick on foam.
Yeah she does not really want the versa to sound aggressive, so no intake for her.
go7roo7 is offline
post #4 of 12 Old 04-17-2014, 12:44 PM
After looking at the videos you provided, I think you are correct regarding the belt tensioner. I take it that the entire assembly comes from the factory pre-loaded with some kind of internal spring mechanism. If that spring has started to lose its tensioning ability, you will start to get the vibrations you mention. Another possibility could be motor or transmission mounts, so you might want to give them a once over. As far as getting the tools in there to get the job done it looks like tight quarters, and you may have to remove some of the surrounding items in order to be able to make the repair. Good luck, and an excellent set of videos.
pimperell is online now
post #5 of 12 Old 04-17-2014, 12:53 PM Thread Starter
go7roo7's Avatar
Thank you for taking the time to view and help me out.
They sell both the individual pulley, and the entire unit together, but I think I will go with the ladder. There is nothing really around the tensioner pulley, I think it has a 1 to 1.5 inch clearance before I hit the fender wall so I need to find some type of torx bit ratchet or something that I can use with an extension to get the leverage to take the part out.
go7roo7 is offline
post #6 of 12 Old 04-17-2014, 01:17 PM
I have a set of those ratchet torx bits, and as I recall, they are not very expensive. When space is at a premium, I use a small breaker bar instead of a ratchet as it saves about 1/2 inch of clearance.
post #7 of 12 Old 04-17-2014, 02:30 PM Thread Starter
go7roo7's Avatar
Yeah with this bolt though the bit stick out about 75% so to add a breaker bar to that is not going to work, I tried it and you can get the bar + the bit in there together, much less turn the bolt out :/
go7roo7 is offline
post #8 of 12 Old 04-17-2014, 04:06 PM
VIM Tools HCT1050 T10 - T50 Stubby 1/2 Cut Torx Driver Set, 10 Piece
post #9 of 12 Old 04-17-2014, 08:51 PM Thread Starter
go7roo7's Avatar
Wont work, there is not enough clearance for even these small Torx and then a breaker bar
go7roo7 is offline
post #10 of 12 Old 04-17-2014, 10:01 PM
jswilson1987's Avatar
Quoted: 12 Post(s)
try using the torx socket with a box end wrench around the hex drive of the torx. You may have to sacrifice one and cut the end off the socket off so its only a hex. Then it can maybe tak welded or quick steeled in place on the wrench
or see if you can get one of these and get a 7/16 wrench around it
Look officer I'm not being a smart ass I'm just saying if you caught me you were speeding too.
'12 HB 6spd
jswilson1987 is offline
