Serious Upgrade Coming! - Page 45 - Nissan Versa Forums
post #441 of 446 Old 01-28-2014, 07:37 PM Thread Starter
versaspeed.com's Avatar
Originally Posted by 07Versa6MT View Post
How is the powerband? Is it a dog at low end now?
No, the SC builds off the normal take off if that makes sense...no lag for sure.
And I have not dyno'd it yet, was more interested in longevity/reliability first and once I get it back together again one of the things I've got planned...
versaspeed.com is offline
post #442 of 446 Old 01-28-2014, 11:32 PM Thread Starter
Hey gang! Just wanted to let you know that I won't be visiting this forum anymore, the group that owns the site wants to charge me because I'm a vendor which is fine but that would drive up prices which I'm not willing to do so if you want to see what's up just follow me on twitter/Facebook/email for questions OR on my ad free websites.
C ya!
post #443 of 446 Old 01-21-2015, 11:18 PM
Hey guys first time here since you guys seem really knowledgeable on Mr motor soon I'm going to be doing a bigger turbine on the turbo in my juke along with crank pulley and bigger intercooler and stuff but wanted to ask if any parts from the mr20 would transfer over to the mr16ddt to help beef up the internals like cams or pistons I'm new to the whole turboed cars and this is my first nissan ever always had Toyotas so some insight would be greatly appriciated
lonewolf1015 is offline
post #444 of 446 Old 01-22-2015, 02:25 AM
4DRZ's Avatar
You really need to do some more research with this before you have some costly repairs...The engine in the Juke is already more stout than the MR20. It has to be simply because it is already turbo. The internals are stronger already to handle the increase of air being force fed back into the motor. You dont need any MR20 donations, what you need is a clear path to your goal. Laying out a goal will help guide you to the correct parts. For instance, a larger turbo may or may NOT be possible without a whole new exhaust manifold...Keep in mind that a larger turbo will lean out the i=engine as it will flow more air. You need to know the duty cycle of the stock injectors because you may already be close to maxing them out. If that is the case, lol, larger injectors will have to be added to your shopping list. A larger intercooler is great and all but you need to know the efficency of the one you have before you waste money on a blinged out larger IC that if its too large will actually cause a pressure drop WHICH will hurt performance. I have been around turbo charged cars most of my adult life, and though there is alot of inexpensive HP to be had, you must know what your doing. Sometimes just swapping the WGA out for one with a stiffer spring will wake a car up and make it a nite and day difference. Read, read, and read anything techy that you can get your hands on about force fed engines. You will learn soooo much! Hope this helps a lil.
4DRZ is offline
post #445 of 446 Old 01-22-2015, 02:29 AM
07Versa6MT's Avatar
Quoted: 127 Post(s)
Pistons, head, and cams are different, bottom end structure is probably all the same from crank down barring additional mounts or flanges added to the original MR casting. I believe the MR was designed as a 2.0 in the drawing board stages and destroked
Direct injection gas is extremely high pressure, generated usually off one of the cams or timing belt/chain, though i believe every gas direct injection system is too new to use that method, they are all cam driven because that is the simplest and most refined method. The head is a different casting redesigned to accomodate the additional length added by the fuel pump lobe.
The MR20 is not too strong in the bottom end, girdle is not too thick, but ok for up to 300HP i would say. I have talked to TURBOSENTRA08 (Jim, highest HP MR20 so far) and he said 300 is a "daily driver" reliable amount, although 500 is not out of the question on stock crank. He has a fully built motor i think. Direct injection should be boost friendly, much more accurate and micro-adjustable, plus higher dynamic compression ratios are attainable for a given octane number. Really better all around. The only problem i conclude with gas direct injection is cylinder wall wetting from poorly placed injectors or re-used combustion chamber design that has large surface area. Realistically it should go full circle to diesel design where there is no combustion chamber in the head, and it's all in the piston. The only reason for that is the manufacturers don't like to disturb the production line too much at once, they are still using very much the same components as the conventional multi-port MR20's/18's. Money basically.
Edit: I just finished posting then saw buddys post above.
To expound on higher boost pressure, he's right, you can screw around with the stock wastegate and a boost gauge to get a little bit more, but realistically that turbo is perfectly sized, for the intended design powerband and desired characteristics. So, it's probably already stretched far enough to provide stock boost, spinning it faster will wind it up too fast and it may not last long.
One day VGT will come to gasoline engines and all of the problems of low RPM boost vs high RPM boost tradeoffs will be a thing of the past.
Also the guy above is thinking a little bit too old school, things have moved on since his frame of reference for getting more power. You can do alot to new cars without having to tune anything, most things will be adapted to with a couple hundred KM of driving. They have wideband/wide range O2 sensors stock, knock sensors and all the usual A/F inputs, safest most idiot proof engines yet. GDI works the same as a conventional multi port system, just higher rail pressure, and more micro-pulsed injection due to faster opening time. They use piezo-electric injectors which are now affordable. Your inputs and feedbacks tell the PCM it is failing to meet the target AF and it subtracts or adds fuel compensating for calculated load, RPM, whatever, then from there we go to fuel trim and blah blah blah.
Grizzly_v2 likes this.
07Versa6MT is offline
post #446 of 446 Old 01-07-2017, 07:11 AM
Location: 9 Lt. J. Francisco St. Quezon City, Philippines
Been looking for answers with the same questions. I agree with your point and thanks to the post and comments, It give me the idea already.
abigailcarson73 is offline
