2010 Versa - Vibration / Buzzing Coming from Passenger-side Rear Near Fuel Tank - Nissan Versa Forums
post #1 of 3 Old 12-06-2015, 11:32 PM Thread Starter
Any ideas on what could be causing an intermittent buzzing or rattling noise in the rear passenger side directly next to the fuel tank. This noise only occurs when idle, once gas is applied the noise stops. It doesn't happen all the time either. Its happening on a 2010 Versa S.
The car has 115,000 miles on it and I haven't had to replace anything fuel related. The noise does not affect performance or driveability. It does not stall or hesitate like you would expect from a fuel problem. I just don't know if the noise is a precursor to a part on the verge of failing. Is there a part that connect to the fuel tank that could be going out? The noise occurred when the car was in my garage this evening so I was able to get underneath the rear of the vehicle and hear where the noise was coming from.
jasonkg is offline
post #2 of 3 Old 07-17-2017, 03:00 AM Thread Starter
Just following up on this thread after 1.5 years later. I'm at 130000 miles now and the noise went away on its own. I didn't have to change any parts or make any changes.
jasonkg is offline
post #3 of 3 Old 07-17-2017, 07:22 AM
Quoted: 102 Post(s)
It could have been anything. I've seen gravel get up into bad places to vibrate to make noise and if it vibrates back out the noise is gone. These seem to be 3 point mounted and on fours that means the pass side can make noise at idle since fours are unbalanced at idle. Why any shaking makes noise mostly then. As soon as the engine moves away from idle the harmonic then is timed so fast it cannot develop to make noise. At idle speeds I've seen that shake affect even the very back of the car.
