changed oil....now it says it overfilled - Nissan Versa Forums
 3Likes
  • 1 Post By pimperell
  • 2 Post By amc49
post #1 of 3 Old 02-28-2019, 12:55 PM Thread Starter
Question changed oil....now it says it overfilled
so we changed the oil and filter and manual says 3.5 qts….so we are done and the oil dip stick says it's over filled...is this ok...has anyone else noticed this...is this common....just leave it or drain the over fill....weird..thanks for any info
slinghigh is offline
post #2 of 3 Old 02-28-2019, 01:02 PM
Depends on how much it is above the fill mark. Too much oil can be a problem so you want to make sure that you try and stay close to the mark. I would take the car for a short spin, park it on a leverl surface, let it drain down for 10-15 minutes and check it again. If it is still showing too much over the full mark I would then drain out a little to adjust the oil level.
slinghigh likes this.
post #3 of 3 Old 03-01-2019, 12:22 AM
Quoted: 97 Post(s)
Up to 1/8" over full mark is fine; drain anything past that. If the crank counterweights strike the oil then vast amounts of air whips up into the oil, aerated oil can fail engine bearings.
If '07-'11 MR18DE engine, then they came with either one of two oil pans on them and dipsticks to match the different oil levels, owner manuals did not reflect that in all cases.
pimperell and slinghigh like this.
amc49 is online now
Similar Threads
Slow cranking. Changed battery, was working fine, now won't crank at all Bren General Technical & Electrical 2 10-15-2014 07:59 PM
Oil Filter changed from topside? topfile General Versa Discussion 21 01-18-2014 11:12 PM
Fiancé says loud exhaust has to go! CB89 Engine Forum 12 07-14-2013 10:42 PM
Oil filter #7317 changed in MR18 motor, pics 08versailles How To's 20 12-11-2012 08:24 PM
Who says the 1.6 sedan can't haul stuff robj80 General Versa Discussion 14 06-21-2011 05:36 PM
