Fly Wheel Bolts - Nissan Versa Forums
post #1 of 8 Old 03-07-2019, 12:45 AM Thread Starter
Fly Wheel Bolts
Changing the clutch in my 2016 Nissan Versa S and wondering if anyone knows about the specs of Fly Wheel bolts? Iv Googled for a wile and cant find anything just the bolt socket witch said they weren't for the versa. Mostly what kind of pattern/torque specs/socket is used. I ordered new bolts from the dealer but he didn't know to much off hand. Has any one else replaced their flywheel?
Run-Em-Till-Dead is offline
post #2 of 8 Old 03-07-2019, 09:37 PM
Quoted: 87 Post(s)
80 ft.lbs.
No pattern, just jump across to opposite side over and over until done. Use a lower step before going higher, it evens out the torque better. Say to 10 all to make sure all bolts and the part are bottomed, then 50, then 80.
post #3 of 8 Old 03-08-2019, 09:15 PM Thread Starter
Thank you for the info, it also for the pattern looks like mine are ether an E-18 or E-20 bolt
ID:	14356   Click image for larger version
post #4 of 8 Old 03-10-2019, 07:31 AM
Quoted: 87 Post(s)
Can't believe they use that bolt head there.........
post #5 of 8 Old 03-11-2019, 03:27 AM Thread Starter
Found out they are an E-20 and you need a flat socket for them. CTA Tools Item #: 9592 works.
post #6 of 8 Old 03-11-2019, 04:31 AM
Why do you say that?
19Versa is offline
post #7 of 8 Old 03-11-2019, 06:02 AM
Quoted: 87 Post(s)
Because I resent the OEMs trying to force people to take the cars in to them only to fix at exorbitant rates, they change the heads of bolts up simply to make the job more difficult, to make you cave in. Not only that, E type socket heads can tear up bolts easier if the socket is not held in true perpendicular to the flywheel surface. The corners round off easier. Not to mention the correct tool can be harder to find if not in the big city.
post #8 of 8 Old 03-14-2019, 04:24 AM Thread Starter
I strongly agree, this has been a "fun" experience. To add to knowledge i also learned that the pressure plate to flywheel bolts specs are 11 Foot Pounds then to 19 Foot Pounds (at least that is what the dealership said). Those are the only torque specs i'v encountered with a flywheel and clutch change. AND A BIG THANKS TO MY BUDDIES WHO HELPED!!!
clutch repair , fly wheel , fly wheel bolts , nissan versa
Similar Threads
2013 Versa 1.6s Muffler Bolts Brett Warner Engine Forum 0 08-30-2018 11:41 PM
Rear passenger seat Bolts for 2007 Versa hatchback Sbanks Interior Forum 1 09-12-2016 08:05 PM
Spring Bolts and Nuts on Exhaust jlifeworld General Versa Discussion 5 12-20-2013 04:46 AM
transmission pan bolts billyz11versa General Technical & Electrical 0 11-10-2013 08:19 PM
Anyone else love to fly? ADOversa Lounge Area 3 03-10-2012 11:25 PM
