Can anyone tell me how to test my 09 Hatchback 1.8 SL CVT ignition coil packs for spark. In many cars I could pull a coil pack while the car is running and use a spark tester or screwdriver to test each coil pack's spark, but for the Versa I have to remove the intake manifold cover just to get to the coils & plugs, removing the ability to run the car and check. Does anyone have a workaround?
I can access #4 on the '09 without removing the cover. I am trying to avoid swapping 3x to check each one, which would mean I would have to remove and put back the cover for each test.
Mis is in cylinder 2, gonna swap, but I want to test them all.
Related Threads
115.5K posts
20.1K members
Since 2008
