2015 foglights - Page 4 - Nissan Versa Forums
 3Likes
post #31 of 37 Old 03-24-2015, 11:45 PM
SV15's Avatar
Quoted: 7 Post(s)
Found these. Anybody have any experience with them?
Spyder® FL-NV2015-C (5080240) - Nissan Versa 2015 Clear OEM Style Fog Lights
Love like you wish to be loved.
SV15 is offline
post #32 of 37 Old 08-26-2015, 03:42 PM
What switch did you end up finding that fit the opening/next to the traction control switch, looks real nice. New to this forum, just bought a New 2015 Versa 1.6 S Sedan, 5-Spd, no options, year end clearance sale for $9,995.00. Anyway am going to get the After Market Fog/Running Light Kit, and thought I might as well order the switch now as well.
ger1986 is offline
post #33 of 37 Old 02-23-2016, 05:29 AM
Did you ever gat an answer on upgrading the OEM fogs to better quality? I am half way through installing Hella mini DE zenon driving lights into the recently price slashed factory fog kit. Dropped from $275 to 53 plus 20 for shipping.
The OEMs require soaking the lens end of the lamp in gasoline for two days to swell the silicone sealer holding the lens to the body. Then pop out the factory reflector, and use a dermel to grind away the nubs holding the steel bulb retaining plates in place. from there it is just a matter of carefully grinding the plastic OEM housing till the Hella lamp will fit in from the back. Watch for alignment there is a top to align on the Hellas. Then trial fit everything before epoxy. Try many times before epoxy. The good news is the wiring harness that comes in the kit will plug directly into the HID ballasts from Hella.
Right now, I have the switch installed, one light converted, but not epoxyed and both blanks opened up. I am struggeling with access to the back area behind the fog lights. I could not get the piece above the grill off after the 5 top clips were removed.
So I have 2 questions for you. Can I access the back of the fog light area from below and wheel well only? And, where is the factory harness connection that is supposed to be behind the driver's side headlight? Thanks. Bob. 14 Note.
If you want a photo of the Hella to Nissan fitment, let me know.
Bob C is offline
post #34 of 37 Old 03-11-2016, 02:24 AM
hello guys!!! question time...........
1. did i read correctly that the sedan SV is already pre wired? if so does that mean from bulb to switch pre wired? or just wired at the bulb area
2. where do you get the factory switch? or is it something that is built in on the headlight stick?
3. are the part #'s L/H 62257-6W80B & R/H 62256-6W80B still correct for the bezels?
4. are the part #'s 26150RH & 26155LH still correct for the lamps themselves?
2015 Blue Nersa SV
bryman31 is offline
post #35 of 37 Old 09-01-2018, 02:07 PM
Originally Posted by dude baker View Post
I replied to your PM. I agree, not OE quality, but better than those big blank pieces of plastic.
I would gladly buy those pieces of plastic lol they cost more than a cheap foglight kit, I have one missing and I am not paying $50 for one!
Pandemonium is offline
post #36 of 37 Old 10-24-2018, 04:08 AM
Versa15's Avatar
Deleted....
Versa15 is offline
post #37 of 37 Old 02-12-2019, 06:04 PM
Scuba's Avatar
Quoted: 12 Post(s)
I just went and did a non factor set up, all the lights are on a 4 switch remote so no wires go into the firewall.
Scuba is offline
