-   -   Bulb Replace Tail Light? (https://www.nissanversaforums.com/general-technical-electrical/2075-bulb-replace-tail-light.html)
speedyv 08-18-2010 06:35 AM
Hi. Does anyone have any experience, know how, how to instructions, advice or something on replacing a burnt out rear brake light bulb. Drivers side if it matters.
Thank you
AzVersa07 08-18-2010 07:33 AM
i've done this several times because i would always smoke my lights, then i blacked them out, then i changed them to after markets and then changed about 2 burnt out tail lights.
Not hard at all!!!
http://i36.photobucket.com/albums/e7...hatershate.gif
speedyv 08-18-2010 07:36 AM
Not hard at all!!!
Okay, I'm not super mechanically oriented but can figure things out with some guidance.
What tools would I need, and how would I go about it?
What should I be careful of doing and well not do. haha
Anyone else if you have some input join in.
Thanks again
AzVersa07 08-18-2010 07:42 AM
tomorrow which would be today, later today i will post pics of the steps. Way easier with words and pics
http://i36.photobucket.com/albums/e7...boydancing.gif
speedyv 08-18-2010 07:51 AM
Thanks that will be great. Look forward to it tomorrow/today. jeez it's late have a good night I need to get to bed haha
JoshG 08-18-2010 01:04 PM
Are you looking to replace your amber bulbs? I have a sedan and someone said the steps are different but you have to pull the housing, and then replace the bulbs.
speedyv 08-18-2010 08:05 PM
Nope Drivers Side Brake Light, the tail light still works light when you turn on the lights it will still light up. But when you hit the brakes the drivers side doesn't get brighter
JoshG 08-18-2010 08:50 PM
Sounds like normal wear and tear. Just get a double function bulb. You might have to remove the housing from the car though.
speedyv 08-18-2010 09:45 PM
Yea my issue is how to remove the tail light assembly.
I figured it was just a burnt out wear and tear. But I have heard it can be a bit complicated for the hatch or any.
Mogh 08-18-2010 10:59 PM
Remove the 2 larger pop out body panels located on the rear on the trunk deck.
Chase down the 2 bolts (10mm) and remove them. One has a plastic clip for a wiring harness on it. Easily removed.
Next, grasp the tail light and pull backwards HARD. There's a plastic clip at the front of the reflector on the side of the car. It's very difficult, and you will feel like its gonna break, but it won't unless you pull sideways at the same time.
The top light is the brake light.
I've seen this written the same way by other ppl, but man, you really have to tug hard.
Here's a picture of the clip.
http://i861.photobucket.com/albums/a...2/DSCN4021.jpg
