mode door control dial not working - Nissan Versa Forums
post #1 of 4 Old 03-24-2015, 06:00 PM Thread Starter
Hey, new to the list, new to the land of Versa.
I have an 09 Versa SL. I bought it basically to let my oldest use when he transcends from permitted driver to junior licensed driver. Anyway.
I noticed the control dial does not turn CCW past defrost/feet mode. I can turn CW to full defrost but it seems that much more comes out of the front vent. Has anyone had this problem? I searched a bit, but really found nothing. One post touched it, but not a lot of info. Someone mentioned a how to fix on YouTube, but no links. I tried searching there as well, but must not be searching on the right stuff.
I did download the FSM, and I see that the MTC section has the info I want, but not exactly sure of the approach. It looks like going in via the passenger side is the way (control cables/lever, etc.), but maybe just open/approach the dial itself?
Again, I have had this car for approx. 1 tank of gas. So far, so good.
Also, has anyone retrofitted stock fog lights into a car that does not have them?
Thanks,
Jim
09 Versa SL hatch
09versajim is offline
post #2 of 4 Old 05-31-2015, 08:59 PM
My wife has a 2009 Versa S with basically the same issue. Was able to adjust the cables so that the system would blow floor and defrost. Here's how you access that area: remove the glove box (screws inside edge of box and under dash), and remove passenger kick panel. Glove box removal is only to have a better visual on what you're doing. Hope this helps. I need to get mine fixed now that the ac is needed instead of heat.
splinter267 is offline
post #3 of 4 Old 05-31-2015, 11:28 PM
OneNutShort's Avatar
Quoted: 8 Post(s)
I'm betting something got lodged in the vent doors. Though I have no idea on how to access those without removing the dash and separating the box from the dash.
OneNutShort is offline
post #4 of 4 Old 06-14-2015, 04:27 PM
OneNutShort is correct !
I took a coat hanger and wiggled it around in each vent ... Bingo ... One to right of the steering wheel was stuck ... Problem solved
Thank you !
btw I replaced a Black super charged 01 GT convertible for this sweet 2009 Versa sedan ... I love the car and the 30 MPG ...
will_01GT is offline
