2007 Versa with tail/brake/turn signal out - Question - Nissan Versa Forums
post #1 of 14 Old 01-27-2011, 01:52 AM Thread Starter
Hi All-
Got a 2007 Versa and the driver-side rear tail-light assembly is out. all lights at one time. is this a relay problem potentially? i checked the fuses and they are all fine. i had all these lights replaced about 10k miles ago. any thoughts???
vince3542 is offline
post #2 of 14 Old 01-27-2011, 04:08 AM
it sounds like a socket problem,
first make sure all sockets are nice and clean, no rust or anything. make sure they have a clean connection to each light
BluV3R18 is offline
post #3 of 14 Old 01-27-2011, 04:56 PM Thread Starter
clean connections
as you probably already know - it's tough to get to the taillights. but you can get to the connections. i checked those and they are all clean and connected.
that's why i'm thinking some sort of relay is to blame.
post #4 of 14 Old 01-27-2011, 05:25 PM
Any moisture in the assembly?
MuzzleNChains is offline
post #5 of 14 Old 01-27-2011, 06:05 PM
try replacing the sockets... keep the receipt and take them
back if they still don't work. gtgI'[email protected]
BluV3R18 is offline
post #6 of 14 Old 01-27-2011, 06:05 PM Thread Starter
good suggestion
everything is sealed up tight. i stuck a compressor hose in through the tiny access holes provided in the trunk. blew everything out and had a little dust shoot out, but nothing else. i can't imagine any moisture getting in there. nissan seals that assembly up pretty tight, but without taking the housing completely off, it's impossible to tell.
post #7 of 14 Old 01-27-2011, 06:07 PM Thread Starter
p.s. taking it to the mechanic today (not the dealership) to see what they say. our local nissan dealership stinks. they want to charge me $250 just for taking a look.
i'll post to the forum with the results.
post #8 of 14 Old 01-27-2011, 06:21 PM Thread Starter
Sockets?
thanks for the tip. i'll ask my mechanic about that when i bring it in.
i'm not trying to sound snarky or anything - i'm just wondering how it would be possible that all three sockets could go out at one time. i can understand if H2O was leaking into the assembly, but that's not happening. i may just have a faulty assembly.
post #9 of 14 Old 01-27-2011, 07:39 PM
westmex's Avatar
If the whole assembly is out, then the problem may not be in the light housing. If you were to put a multimeter in the wires and check for power, that would tell you if the problem is in the housing or in the wiring. There may be a loose connection elsewhere in the circuit.
Mods:
Tint 35% front, 20% back
westmex is offline
post #10 of 14 Old 01-27-2011, 10:43 PM
To be honest, I do not have a clue why the tailight is out, I'm just trying to help you figure it out from my end of the world
I would never think you're trying to sound smarky or anything because you're just trying to get your lights fixed.
sometimes one bad socket can cause the other 2 sockets to shot down for safety reason, but I'm not 100% sure if that's possible. that's just something that I would do if I had the same problem.
but before going out and buying new sockets it is best to check if all sockets are actually getting power. you can test each socket using a multi-meter.
if they're all getting power, make sure all light bulbs are good too.
if all sockets are getting power, all light bulbs are good, and still no power from that tail light, then I don't know, I would have to think of something else or take it somewhere and let them figure it out.
the main question is, are those light bulbs getting power?
probably not, and that's why they're not working
or is one light bulb bad causing the other two not to work?
not lilkely...but its worth to try
is the fuse good?
I don't know
it could be something simple or it could be something complicated
Does anyone else have more ideas?
BluV3R18 is offline
brake light , tail light , turn signal
