2009 Nissan Versa "Fuel Pump" - Nissan Versa Forums
post #1 of 5 Old 08-11-2011, 07:51 PM Thread Starter
2009 Nissan Versa "WON'T START". Checked the battery. Customer ran it til it was dead. Charged it. No start. No fuel at the rail coupling. Need to jump the wires at the fuel pump (under the passenger rear seat) and test it. What wire is + and -?
Ryanmillay is offline
post #2 of 5 Old 08-11-2011, 11:09 PM
08versailles's Avatar
Quoted: 53 Post(s)
use Search in forum for FPR or fuel pressure regulator. just changed mine. known issue, cheap fix. sorry dont know pos or neg on pump, but someone will!
if the fpr is done, dont replace the whole pump!
when mine went, it took loads of pedal pumping to start it, but after it finally started, it ran flawlessly. probably your fpr! hope it helps. 08v
08versailles is offline
post #3 of 5 Old 08-12-2011, 01:48 AM
06_warrior's Avatar
When you turn the key on do you hear the fuel pump make a whine sound? If it's hard to hear that try taking out the back seat so you can listen for the whine from the fuel pump when it gets energized. The fuel pump is under the back seat.
06_warrior is offline
post #4 of 5 Old 08-12-2011, 06:26 AM
I agree, you need to check if the pump kicks on when you turn the ignition key
2007 HB 6spd manual Previous
2014 Nissan Sentra Current
BluV3R18 is offline
post #5 of 5 Old 08-12-2011, 12:06 PM
Banned
pump
if it was the pressure reg it would crank, but eventually start. No fuel at rail=pump.. at least on a versa
jbeau is offline
fuel pump 2009 versa
