Installing an aftermarket radio problem - Nissan Versa Forums
post #1 of 15 Old 03-16-2017, 03:02 AM Thread Starter
Hi, I have installed many radios and I am getting ready to install one in my daughter 2007 Versa. Question for you : I have two black ground wires,One on the radio harness and one on the new adapter harness. I plan on grounding them separately SOME PLACE. I did see a video where a man suggested to the back where that little storage area is above the radio. In the video this man only grounded ONE wire. What is you take on that? Thanks
Sue Kretock is offline
post #2 of 15 Old 03-16-2017, 04:23 AM
Im preparing to install an aftermarket radio and I too was made aware that you need to supply a ground as they did not use one or something like that.
post #3 of 15 Old 03-16-2017, 08:55 AM
Quoted: 11 Post(s)
Yes Nissan does not ground their radios in the harness. Their radios ground when they are mounted in the car through their chassis. Aftermarket radios will not work this way since they are usually mounted in a plastic dash kit. So you have to make your own ground.
Sent from my SM-G920P using Tapatalk
TNAudio is offline
post #4 of 15 Old 03-16-2017, 03:38 PM Thread Starter
Thank you. I know I have to ground for sure and yes it's all plastic. I guess I have to ground two black wires since I have two open ones. If I can't find a spot for one I guess I can buy more wire and pass it down below the dash. One according to the video can be found where that upper compartment is inside the dash. Nice to have so much plastic. HAHAHAHA I was searching on Crutchfield and they said IF you have the metal brackets that attach to the radio like the one you have from the old radio (Even if there is plastic on the other side) you can attach the ground wire to that. But that looks like a double DIN radio and I don't have that. Plus I have the plastic brackets. I don't see a way to convert that metal bracket to mine. If I could then I would attach one ground to that.
post #5 of 15 Old 03-16-2017, 03:43 PM Thread Starter
Well I have two grounds. Lol And alot of plastic. Lol I said in another comment what my plan is and we'll see.
THEN I read last night the blue wire in the antenna adapter is a ground too. HAHAHAHA Someone told me to hook it to the blue/white wire. I hope they're right.
post #6 of 15 Old 03-16-2017, 10:34 PM
I always use the blue antenna wire to remote assuming its an amplified antenna.
post #7 of 15 Old 03-17-2017, 12:00 AM Thread Starter
That's what I did. Thanks for saying you did that also. I have done LOTS of searches on this subject
and found that's what someone others have done. So I guess I will connect both ground wires separately somewhere. I will buy a foot of wire for one of the ground wires because I have a feeling I am going to have to route it somewhere
away from the radio area. Lol Unless someone has an easier way.
post #8 of 15 Old 03-17-2017, 08:48 AM
Quoted: 84 Post(s)
You can ground both wires at same place, and be SURE they are grounds. While commonly so they do NOT have to be; some odd makers use black wires on other things. Easy to think wire is all black too if it is black with a dark blue tracer, the blue merges right into that black in the dimmer light of a radio hole. The plastic of the dashes commonly attaches to a metal matrix support deeper in the dash structure, sometimes you can get to part of it at the glove box, I use that on Fords as no tools are required to drop those boxes down to expose a big hole you can get hands and a drill into to drill a ground screw hole into that frame, it often runs right beside the glove box area. That frame also common to run behind the radio too.
Some radios actually call out for the radio outer case to ground as well as one of the wire leads, extra grounding never hurt anything.
post #9 of 15 Old 03-17-2017, 04:29 PM
Quoted: 40 Post(s)
Not likely... I smell blown fuses in your future lol
The metal arms that the four bolts of the stock radio go into are perfectly good grounds. That is probably where your plastic radio adapter is bolting to I'm guessing? Should still be able to go an eyelet connector there no reason to looking for ground deeper in the dash. No reason to ground your two ground wires separately either, just making more work for yourself.
I still don't understand how you end up with two ground wires, but we don't have any pictures of your setup or anything so who knows. Go slowly and carefully and I'm sure you will get it figured out.
arudlang is offline
post #10 of 15 Old 03-17-2017, 04:30 PM Thread Starter
Thanks so much. I get what you mean. I do remember a ground being brown on some older stuff. Thanks for bringing up about the black with a dark blue tracer. I seem to remember that now when I used make harness's etc. at my former job. Right, The plastic has to be attached to metal some place. Oh ya I know my Ford Mustang has plenty of grounding areas and it was no problem. I'm sure I'll find something with the Versa. Thanks so much for replying. I wish that picture would work. I have one ground coming out of the pioneer harness and one ground coming out of the new adapter harness. They are not attached to anything.
