No Smoke with Seafoam Spray - Page 2 - Nissan Versa Forums
 3Likes
post #11 of 19 Old 05-14-2017, 09:04 PM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
The brake line hose on the 2014 versa connects to the brake fluid resevior and goes all the way around to the manifold.
whicky1978 is offline
post #12 of 19 Old 05-14-2017, 09:06 PM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
post #13 of 19 Old 05-14-2017, 09:40 PM
Quoted: 44 Post(s)
Originally Posted by whicky1978 View Post
Yeah, run Shell premiun 95% of the time.
Well, it being premium or regular has nothing to do with a quality of gas. And if you use premium for Versa, it is just a waste.
post #14 of 19 Old 05-14-2017, 11:38 PM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
The premium has more detergent in the regular.
Cobb likes this.
post #15 of 19 Old 05-15-2017, 12:46 AM
Cool
Its a ten year old van I purchased used with 100k miles on the clock. You think Id take such lousy care of a vehicle to get in that shape if I owned it since new?
Originally Posted by amc49 View Post
To Cobb, how do you have all those problems to even begin with? The FI system has been 100% flawless on every MPFI car I've ever had.
+1 on higher octane fuel and top tier. I like BP myself as they sell 93 octane and use nitrogen. You know, the same stuff thats in my tires.
Next time yaw get low on gas put a few gallons of premium top tier and go for a short drive and tell us what your butt dyno reports, especially the stick shift drivers.
post #16 of 19 Old 05-15-2017, 06:48 PM
Quoted: 40 Post(s)
I've absorbed a lot of information from discussions like this on many many forums, at this point my conclusion is simply that there are too many complex systems interacting with too many variables and too little data/tests to ever confirm what any individual *thinks* a product did or didn't do for their motor.
The biggest two problems are
1) The number of tests/sample size is too small. Any one treatment you give a motor that happens to coincide with the abatement of an issue is not proof of anything in the complex system of a computer-controlled ICE.
2) The external observations of a user are limited and easily skewed and/or misunderstood. This one comes in two parts:
2a) - When no change or effect is actually present: The mind is so incredibly easily fooled, the senses so unreliable, that in these cases what your brain *thinks* it perceives is totally self-manufactured. Ask any individual and their ego will likely have them saying "Maybe some people, but not me! I'm amazing!". Sure you are... the computer says the running temperature is the same, the timing being pulled on the ignition unchanged, the readings from O2 no different, etc, but YOU are far more sensitive than the computer somehow, and you can miraculously detect some change that the computer and all its sensors can't even read. Riiiiight. I'm sure you can also *see* auras and detect the rotational direction and speed of the planet, and the gravitational pull of the moon at night. Good for you.
2b) - When a change or effect IS present, but the cause and effect is misunderstood: You've got some bad gas in the tank. Happens all the time. You drive a couple hundred miles with the crappy gas thinking "boy, the poor car sure is running rough these days". You go to the gas station, put in 7 gallons of fresh fuel and a bottle of STP or whatever your favorite donation to the industry is. "WOW! It runs so much better! That additive is really amazing!" Yeah or probably just having fresh un-tainted gas is amazing.
If a computer sensor or dyno can't detect the change, I know I don't have the audacity to claim that I can detect it. If there is a change that the computer or the computer and I both can detect, a grain of salt and some critical thinking about how many variables and factors go into how well any engine is running at any given moment is in order and without laboratory controlled conditions, disassembly & inspection and A-B-A testing, no conclusion is fully supported BUT I will happily drive the car as long as it seems better and not worry about it too much.
Long and short, there is nothing wrong with throwing a little money away (I mean at) a problem in the way of additives or whatever to see if it helps and if the car is running good when the smoke clears then great, all done. The issue is taking that anecdotal evidence and unreliable butt-dyno reading and claiming with absolute certainty that it did what you think/hope it did and pushing it on others, and/or throwing it out there on the internet in hopes that the other believers will chime in and support you to further make you feel better about the money you spent. Group mentality and all... =P
arudlang is offline
post #17 of 19 Old 05-16-2017, 11:51 PM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
I did notice my fuel economy improved bit until I burned through that seafoam in my gas. The average mpg meter jumped to 39.9 and normally runs 38.5 to 38.7 (real world 34-36 mpg). it might be good to add to the gas tank on a long road trip.
It does seem like in the long run it would be cheaper you're a fuel injectors cleaned by hand instead to keep adding chemicals.
post #18 of 19 Old 05-17-2017, 03:00 PM
Quoted: 81 Post(s)
EXACTLY post #16 , anything else is self-bullsh-t. Nothing wrong with a wee bit every now and then but I choose to not even do that. My head needs no fix from it. If you firmly think you have to run additive all the time the car problem is one that can actually be seen by looking in a mirror.
People HATE being told that but that in no way changes the truth of it. Ask the car if it knows when you are running additive..................the major separation of fault that has to happen anytime a car needs to be repaired...................what part is car and what part is owner.
post #19 of 19 Old 05-18-2017, 06:14 AM
Quoted: 81 Post(s)
Premium fual generally DOES have a bit more detergent in it as a selling point but the thing to remember is that even the lowly regular blends have to have a certain amount in them and it has to be enough to pretty much keep parts like injectors clean or you would see lawsuits like nobody's business.
