-   -   Error code P0705 (https://www.nissanversaforums.com/general-technical-electrical/39474-error-code-p0705.html)
driver1234 09-30-2017 02:46 AM
Error code P0705
Hello everyone,
For starters: the car I'm driving has less than 30k miles and is a 2014 Nissan Versa 1.6 SV.
For the past week or so, I've had the yellow, non-blinking Check Engine Light on. The car seems to be driving perfectly fine, with nothing out of the ordinary.
Finally took it in for a diagnostic and got P0705 as the error code.
Has anyone else experienced this problem? Is this something I can fix pretty easily? Cost estimates?
I appreciate any input.
Cobb 09-30-2017 08:52 AM
Googling it looks like the indicator switch for what you have selected that is on the cvt. Depends if you can get the part. A lot of cvt parts you can remove, test, but Nissan does not sell. Your choice is to get one from a junkyard or replace the whole cvt.
pimperell 09-30-2017 01:20 PM
Originally Posted by driver1234 (Post 271322)
Hello everyone,
Your best bet would be to bring the car into your Nissan dealership for diagnosis. This particular issue may be covered under the "Power train" warranty which runs for 5 years or 60,000 miles.
Without the proper diagnostic tools and software, you may be shooting in the dark trying to make the repair yourself. Good luck!!!
Possible causes Faulty Park/Neutral Position Switch Misadjusted Park/Neutral Position Switch Park/Neutral Position Switch harness is open or shorted Park/Neutral Position Switch circuit poor electrical connection What does this mean? When is the code detected? The transmission range switch detects the selector lever position and sends a signal to the TCM. Possible symptoms Engine Light ON (or Service Engine Soon Warning Light) P0705 Description The park/neutral position (PNP) switch includes a transmission range switch. The transmission range switch detects the selector lever position when the shift lever is in the N or P shift position and sends a signal to the Transmission Control Module (TCM).
Read more: https://www.autocodes.com/p0705.html
David Roth 06-06-2019 07:52 PM
I'm not going to suggest the best thing for you to do but what I found was a link to something that made sense in my case. Nissan Versa Hesitation, P0705 ? Ricks Free Auto Repair Advice Ricks Free Auto Repair Advice | Automotive Repair Tips and How-To
My driver side rear running lamp and turn signal bulbs were not working causing the common fast blinking situation. Replaced the bulbs, lasted a while, and then it started happening again but under closer inspection, found that the bulbs were fine.(swapped them with the passenger side). Reason why I mention this is when I looked up the P0705 (Advanced Auto Parts free scan) it translates to a Transmission Range Sensor A circuit. Now at 103K, I thought my CVT was just getting old/worn and maybe the belt was the culprit. The link suggests that you check inside your tail lamp assemblies for corrosion before replacing the Range Sensor. I'll do that this weekend. If replacing the range sensor is the solution, I'll be back to see if anyone knows where it is located on a '13 Versa sedan CVT.
PoMan 06-19-2019 07:48 PM
It is amazing how a seemingly unrelated electrical component can induce enough noise/disruption into a circuit to effect something else. I've not run into this, but I've seen various youtube videos on it. Problem is, finding a tech who's willing to troubleshoot to this degree, has the resources and experience is tough.
pimperell 06-20-2019 12:00 PM
Click on the link below, then click on the "Nissan recall campaign bulletin - NHTSA" which will open up a PDF file pertaining to your issue.
https://www.google.com/search?client...t+range+sensor
