How much gear oil? - Nissan Versa Forums
  • 1 Post By whicky1978
post #1 of 10 Old 06-17-2018, 04:18 AM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
How much gear oil?
Will I ned more than a quart of Nissan-MTF to replace my gear oil?
whicky1978 is offline
post #2 of 10 Old 06-17-2018, 12:54 PM
Not knowing the year or model of your car, the below link is for a 2009 versa:
https://www.amsoil.com/MyGarage/Vehi...DATSUN+VERSA+1
post #3 of 10 Old 06-17-2018, 02:49 PM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
Its 2014. Looks like I need to buy 3 quarts. https://www.amsoil.com/MyGarage/Vehi...DATSUN+VERSA+1
post #4 of 10 Old 06-18-2018, 01:34 PM
I am sure you know this, but just make sure you can loosen the fill up plug before you drain the transmission fluid.
post #5 of 10 Old 06-19-2018, 02:25 AM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
Good point. I will have the peice i need and will use a mallet if need to lossen it. Both need to be open for maximum drain. but yeah be totally screwed if I got the bottom open and can’t get the top 😳
post #6 of 10 Old 06-20-2018, 02:09 PM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
I got a 10 mm square head socket and it was too big. I did not get to change my gear oil today ☹️. Can somebody tell me if a 8 mm is the right size?
CTA Tools 2036 Square Head Drain Plug Socket, 8mm https://www.amazon.com/dp/B00FRLBF4M..._diLkBbTG18WR4
post #7 of 10 Old 06-20-2018, 04:11 PM
Here is everything you want to know regarding the tranny. I believe is is 8mm, but just to make sure read through the shop manual:
https://www.scribd.com/document/3177...nsmission-Info
post #8 of 10 Old 06-20-2018, 06:10 PM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
Thank you. This is very helpful. It may also be possible to pump/siphon the gear oil out.
post #9 of 10 Old 06-20-2018, 11:22 PM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
I got it done and take pictures. I plan to do to DIY thread. Seems to shift better. The old gear oil did not look too dirty at 86k miles.
post #10 of 10 Old 06-20-2018, 11:52 PM
Its bigger than 3/8 but not by much.
You really want to remove the drain plug as its a magnet and clean the crap that has stuck to it. If its a used car, it gives you an idea how much wear has already occured.
+1 on removing the fill plug before the drain. Not that you cant use a cleaned out caulk tube to shoot oil into the drain hole and plug it fast, but its easier to use the fill hole.
Yeah, I hope to put royal purple in my tranny this weekend. My socket from amazon was an add on, so I had to buy like 25 bucks worth of toilet paper to get it.
