A/C Compressor CR-10 6 ribs but will a 7 rib pulley work? - Nissan Versa Forums
post #1 of 4 Old 06-29-2018, 01:54 AM Thread Starter
So, my A/C Compressor's bearing gave out and it's LLOOUUDD grinding and clanking!
I ordered a part of eBay and saw the new assembly has 7 ribs instead of 6. I test fit the belt and it does fit but one extra rib is visible.
Is this OK to use and won't be a hazard later? I tried looking for a 6 ribbed pulley but can't seem to find anything anywhere; without having to buy a whole new compressor.
I imagine it's perfectly fine as long as I align the belt perfectly.
Greatly appreciate y'alls input!
rlmerrell69 is offline
post #2 of 4 Old 06-29-2018, 07:59 PM
I agree. Just make sure it aligns up and you align up the belt too before tightening it up.
post #3 of 4 Old 06-30-2018, 02:52 AM Thread Starter
So I installed everything... But the clutch keeps rubbing on the pulley! when not tight, it's fine. But once I tighten the hex key bolt, the pulley doesn't turn freely. I've got the original 2 spacers that were in the old clutch, one was SUPER thin and the other thick. And the 2 new spacers which, when put together, match the size of the original thick spacer. Should I go out and get more spacers? What could I use as spacers if I find none?
Help help! I've been eaten my mosquitoes and a bit worried about this new clutch assembly.
post #4 of 4 Old 07-01-2018, 10:04 AM
Quoted: 84 Post(s)
Your new pulley is deeper and you needed to buy the faceplate that matches it. With a longer stand in the center. You will need a whopping amount of washer to make your original part longer there and then the bolt will be too short to strip out once you tighten it, you'll need a longer bolt likely too.
When done you are supposed to have .015"-.030" airgap in there to allow the plate to not touch but be close enough the magnet easily pulls it shut to lock.
