Figure this out? - Nissan Versa Forums
post #1 of 18 Old 08-16-2018, 04:19 AM Thread Starter
Versa15's Avatar
Quoted: 8 Post(s)
Deleted...
Versa15 is offline
post #2 of 18 Old 08-16-2018, 08:14 AM
Short somewhere to create issues in other circuits...............have fun with that one.
post #3 of 18 Old 08-16-2018, 02:32 PM
Originally Posted by Versa15 View Post
My 2015 Versa SV sedan has begun losing power when taking off from a stop. It feels like I'm pulsing the throttle. After the third or fourth time experiencing this, I realized I only noticed this happening when I slowed or stopped and made a right turn. Never to the left. Odd?
Today I'm walking away from the car and hit the lock button on the remote and the rear right turn signal doesn't flash. I check and the bulb isn't blown but just barely glows.
Hour later I'm driving on the interstate and make a lane change. As the right turn signal is blinking, the engine is cutting out again. That's when I realized the pulse of the engine cutting out is with the turn signal. Seriously! Can this car get any weirder
Grasping at straws here............try removing the bulb from the right rear turn signal and see if there is any difference. If not, see if there are any codes being stored. Most auto supply stores will check for codes for free. While you are there, have them check you alternator and see what kind of voltage it is putting out, and have the battery tested under load. Be sure to check out the battery terminal posts and clamps for any corrosion . If all that checks out as o.k., I would then check all of the fuses for any type of corrosion. Pull the fuse out, check it with a multi-tester to make sure it is good, use electronic contact cleaner, and then re-insert the fuse. I know that this will take a little work, but it is not costing you any cash at this point. Good luck!!!
pimperell is online now
post #4 of 18 Old 08-16-2018, 04:40 PM
Yeah I would guess short someplace. The funny thing is that I just watched a youtube video about a guy chasing several unrelated electoral issues. Come to find out, all the effected systems shared a harness connection that had melted and started to fuse the wires together.
Maybe chase the blinker circuit all the way back to the battery and see if you find any issues.
**But i'm just guessing**
scarecrowdjinn is offline
post #5 of 18 Old 08-16-2018, 10:09 PM Thread Starter
Versa15's Avatar
Quoted: 8 Post(s)
Deleted...
Versa15 is offline
post #6 of 18 Old 08-16-2018, 10:27 PM Thread Starter
Versa15's Avatar
Quoted: 8 Post(s)
Deleted...
Versa15 is offline
post #7 of 18 Old 08-16-2018, 10:57 PM Thread Starter
Versa15's Avatar
Quoted: 8 Post(s)
Deleted...
Versa15 is offline
post #8 of 18 Old 08-16-2018, 11:16 PM Thread Starter
Versa15's Avatar
Quoted: 8 Post(s)
Deleted...
Versa15 is offline
post #9 of 18 Old 08-23-2018, 01:48 PM
How goes it? any update?
post #10 of 18 Old 08-23-2018, 10:45 PM Thread Starter
Versa15's Avatar
Quoted: 8 Post(s)
Deleted...
Versa15 is offline
