2011 Versa 1.8L PCM/ECM/ECU Issues? - Nissan Versa Forums
post #1 of 2 Old 08-19-2018, 11:00 PM Thread Starter
Jeff Anderson's Avatar
Angry 2011 Versa 1.8L PCM/ECM/ECU Issues?
Greetings.
I'm new here & new to the world of Versas.
2011 Versa S 1.8L auto(non-cvt) 5 door hatchback.
Having some very strange issues.
I think the alternator may have been charging way too high (15V).
The bearings were squaking, so I replaced it with one from a bone yard.
Verified 14V after first starting.
However, now it has trouble starting & driving.
Threw codes for the Accelerator Pedal Position sensor so I replaced that with one from a junkyard.
The codes have not gone away, no matter how many times I clear them with my scan tool.
Sensor D shows a % when applying the pedal, but sensor E shows nothing.
I'm not sure if the new-to-me APP is bad or if there is an issue from the alternator.
Randomly, I'll get a code for the crank sensor or other things and the power is way down.
When driving, the cruise will not set, the rev limiter hits at 2600RPM in 1st gear & at ~4500RPM in 2nd.
When touching the brake pedal & accelerator pedal, the engine will "die" to idle.
When driving slowly & pressing the accelerator to the floor, it will not downshift & gains speed very slowly.
So. Does it have a PCM or ECM or ECU?
How can I check the PCM/ECM/ECU to see if it is working correctly?
How can I check the APP to see if it's working correctly?
TIA
Jeff Anderson is offline
post #2 of 2 Old 08-22-2018, 11:22 AM
Quoted: 92 Post(s)
Originally Posted by Jeff Anderson View Post
Greetings.
TIA
Give this a try..............and see if it helps:
pimperell is online now
