Car jerking while accelerating. - Nissan Versa Forums
post #1 of 7 Old 02-01-2019, 05:07 AM Thread Starter
Hi guys,
So recently my car has been having issues where while i'm accelerating if i lightly tap the gas pedal the car will jerk pretty hard back and forth. It happens a lot (not all the time) at higher speeds say at 60 k/m and up, but some times even at low speeds. I've tried changing the spark plugs, coils, engine mounts (top, rear strut mount). the vehicle is at 135,000 km. it's a 2012 1.6 CVT. Hopefully someone can shed some light on this issue.
StephenWong is offline
post #2 of 7 Old 02-01-2019, 05:55 AM
Could be the trans itself.
post #3 of 7 Old 02-01-2019, 03:34 PM
Can you recreate the problem while in neutral? It might help with trying to figure out if it's an engine problem or a transmission problem.
Also note the RPM's when it happens again.
I would also check the transmission fluid: Level, color, and feel (rub your fingers together, check for slickness)
scarecrowdjinn is offline
post #4 of 7 Old 02-05-2019, 07:19 PM
Hey guys, im the OP. Forgot my password and the forumn doesn't reset ur password for some reason.
After spending hundreds of dollars on this car I finally figured it out.
So, I tested if it did the same thing while in park and neutral and unfortunately it did. So I went back to the basis of the problem, which started with the spark plugs, after i checked all the spark plugs and replaced them, as i was putting everything back together it had me thinking. It would happen everytime i lightly tap the gas so im assuming it had something to do with the MAF sensor or the MAF itself. After checking the sensor i found out the connector that had a plastic clip was broken. So I put on the MAF connector on loosely and took it for a drive, this time it had the same issue but was even worse, so when i pushed it in tightly and test drove it, i discovered the issue had been resolved. Looks like I have to replace the connector. Anyways hopefully this will shed the light on anyone else that is having a similar issue, check the harness first, before replacing a bunch of other things on ur car.
[email protected] is offline
post #5 of 7 Old 02-05-2019, 11:11 PM
Quoted: 48 Post(s)
Thanks for the update. How the MAF connector got broken in the first place? By itself?
post #6 of 7 Old 02-06-2019, 02:06 PM
Congrats on the fix!
Thanks for letting everyone know the solution. It really helps the community.
post #7 of 7 Old 02-11-2019, 08:14 PM Thread Starter
I think whoever touched my car broke it LOL.
Similar Threads
Slight vibration in 4th gear while moving and while at certain rpms silverflash Engine Forum 2 08-29-2016 07:21 PM
Rattling Noise when accelerating? Newman General Technical & Electrical 4 02-07-2014 04:00 PM
2010 Versa non cvt not accelerating when lights are on. cdub856 General Versa Discussion 7 10-12-2013 09:40 PM
Rumble When Accelerating from Stop during Test Drive TKO General Versa Discussion 0 09-23-2013 06:17 PM
rattling noise when accelerating at 2 RPM viet510racer Engine Forum 11 03-06-2013 01:38 PM
