2010 versa hatchback no crank - Nissan Versa Forums
post #1 of 8 Old 05-22-2019, 01:15 PM Thread Starter
2010 versa hatchback 1.8 auto cvt good battery starter and relay new nuteral switch at the linkage on trans new MAP NO CODES as well.
key turned to on postion all is good then to the start postion all lights on instrument panel go out no volts to starter solidnode but the rely energizes. Same set up but manually engage the starter relay motor turns over but wont start. any kinda of guess would be appreciated please let me know if more info is needed.
B Brandon Hall is offline
post #2 of 8 Old 05-23-2019, 12:28 PM
[QUOTE=B Brandon Hall;288590]2010 versa hatchback 1.8 auto cvt good battery starter and relay new nuteral switch at the linkage on trans new MAP NO CODES as well.
key turned to on postion all is good then to the start postion all lights on instrument panel go out no volts to starter solidnode but the rely energizes. Same set up but manually engage the starter relay motor turns over but wont start. any kinda of guess would be appreciated please let me know if more info is needed.[/QUOT
I know you checked the battery and it should should come in as listed below. Next, I would check the battery terminals, remove the connections, clean the posts and clamps and reconnect. I that fails to remedy the situation, I would then check all fuses to insure that none are blown. My normal procedure is to remove the fuse, check it with a multi tester to insure that it is good. Sometimes a fuse can blow and it is not noticeable to the naked eye. Hope this gives you some ideas in order to correct the problem you have!!!
Fully charged automotive batteries should measure at 12.6 volts or above. When the engine is running, this measurement should be 13.7 to 14.7 volts. If you don't have a multimeter to tell you the voltage of your battery, you can do a test of your electrical system by starting the car and turning on the headlights.
post #3 of 8 Old 05-23-2019, 09:41 PM
Quoted: 94 Post(s)
Until the battery is loadtested at correct CCA there is zero proof it is good.
post #4 of 8 Old 05-26-2019, 08:47 PM Thread Starter
yes mca49 the battery was load tested and even switched it with another one that tested good(cca) as well. All fuses and relays were test out of the circuit and retested when put back in the circuit. I will double chk. Is there any ground thats prone to losing ground on the versa?
When you turn to the on postion it sounds like it should you can hear everything energize. Then turning the key to start the ignition/starter relay is energized and then all indicator lights go out. Is any of the other relays like an ASD AUTO SHUT DOWN relay like on Dodges? Why wont it start when the key is in start position and we manually energize the starter to get the motor to turn over. Does any one have a pin out of that circuit and/or of the PCM or ECM?
post #5 of 8 Old 05-27-2019, 11:17 AM
Found this while doing a search.............sounds weird but who knows................give it a shot and see what happens. Good luck
There are three large bolts in the driver's door jam. These bolts ground the body of the car to the frame. With a socket wrench, tighten all three bolts in order to make a solid ground to the car frame.
post #6 of 8 Old 05-28-2019, 06:03 PM Thread Starter
I will definitely chk those bolts for ground. When its electrical and with some of these circuits nothing is to far out there.
post #7 of 8 Old 05-30-2019, 02:56 AM
Quoted: 94 Post(s)
https://forums.nicoclub.com/versa-te...scussions.html
Go there, register for free, and the service manuals can be downloaded using the link at top of page. Thinking section PG is power and grounds.
Testing fuses can pass all day long if the fuse is still partly connected but say melted 3/4 of the way across. Then full battery power does not go through the system but part tests perfect all day long. Meaning have a CLOSE look at the battery fuse link in the battery cable. Your problems seem to say low power, the starter if working by jumping it can pull enough power off the ECM to not power up the spark. Same with dash lights going off at starter on.
post #8 of 8 Old 05-31-2019, 05:09 PM
Does your car have the Anti-theft chip?
I'm don't remember, Does the anti-theft chip keeps the car from starting, or just cranking?
scarecrowdjinn is offline
Similar Threads
2008 TIIDA / VERSA no crank no start BoogWar General Technical & Electrical 10 01-18-2019 08:14 PM
08 hatchback versa A/T crank no start no communication with any module. fan on Ridha Bouneb General Technical & Electrical 14 11-29-2018 05:04 AM
Versa 2008/No start no crank / dash has power / battery has power / Jumpstart did not jack10901090 Engine Forum 4 09-28-2017 08:59 PM
Versa 2008/U1000/No start no crank / battery has power / Jumpstart did not work jack10901090 New Members 1 09-28-2017 12:25 PM
09 nissan versa crank no start kev63rod General Versa Discussion 4 06-06-2017 03:37 AM
