Power to radio not turning off after key is removed - Nissan Versa Forums
  • 1 Post By pimperell
post #1 of 5 Old 05-23-2019, 12:51 AM Thread Starter
Hi... First post here:
I was hoping to find some help with an issue I’m having with our 09 versa hatchback.
When we turn off the key there is still power going to both the radio and 12v accessory socket. If the power button on the radio is pressed the radio itself turns off, but the clock is still illuminated. Turning the clock off using the clock button doesn’t stop the power drain as the battery is dead if it sits too long (overnight). Normally the accessory socket (12v cigarette lighter socket) will not work with the key removed but now it does.
I have done a little research and have not been able to get a clear answer.
All the fuses are seemingly good... but I didn’t think it would be a fuse since I figured they would STOP the power flow.
Any ideas on where to start and how to diagnose?
TIA!
tricky48 is offline
post #2 of 5 Old 05-23-2019, 11:54 AM
Quoted: 92 Post(s)
I was hoping to find some help with an issue Iím having with our 09 versa hatchback.
When we turn off the key there is still power going to both the radio and 12v accessory socket. If the power button on the radio is pressed the radio itself turns off, but the clock is still illuminated. Turning the clock off using the clock button doesnít stop the power drain as the battery is dead if it sits too long (overnight). Normally the accessory socket (12v cigarette lighter socket) will not work with the key removed but now it does.
All the fuses are seemingly good... but I didnít think it would be a fuse since I figured they would STOP the power flow.
TIA!
Found this while doing a search.............sounds weird but who knows................give it a shot and see what happens. Good luck
This was a very strange problem and the fix was even stranger. There are three large bolts in the driver's door jam. These bolts ground the body of the car to the frame. With a socket wrench, tighten all three bolts in order to make a solid ground to the car frame. Your trouble of the radio staying on and killing the battery will be fixed.
SlickVersa likes this.
pimperell is online now
post #3 of 5 Old 05-23-2019, 10:22 PM
Quoted: 84 Post(s)
If a fuse blows to STOP power it may be doing that on a control chip that controls other devices to no longer turn them off.
In today's world you often have to think backwards to go forward.
FYI, on modern unibody there is no 'body' or 'frame' any longer, they are one piece, sometimes supplemented by a small subframe in the front or back with no electrical in it. Still, I would look into those bolts, they add grounds all over the cars today and there are reasons for them.
post #4 of 5 Old 05-23-2019, 11:25 PM
Quoted: 84 Post(s)
Try mirrors and see if they work, if so, there is an accessory relay that if stuck on would do that.
post #5 of 5 Old 05-28-2019, 10:57 PM
Retained accessory power?
If you have retained accessory power it should turn off any accessories when you open the door after turning off the car. Probably controlled by the BCM. If this is not functioning properly, you may have to replace the BCM! $$$
Lew George
2017 Nissan Versa Note SR
Grey / Charcoal
hlgeorge is offline
Similar Threads
Versa 2008/No start no crank / dash has power / battery has power / Jumpstart did not jack10901090 Engine Forum 4 09-28-2017 08:59 PM
Key removed. Alarm continues rjohnston General Technical & Electrical 3 04-29-2013 12:45 AM
Upgrade to power windows, power lock, power side mirrors for the 2011 Versa 1.6 wei11364 General Technical & Electrical 11 09-21-2010 06:51 PM
Radio Light comes on after key removed AltaVersa General Technical & Electrical 2 06-02-2010 02:20 PM
Intelligent key not working after installing LED sills oozair General Versa Discussion 1 10-29-2008 06:43 PM
