Hi... First post here:
I was hoping to find some help with an issue I’m having with our 09 versa hatchback.
When we turn off the key there is still power going to both the radio and 12v accessory socket. If the power button on the radio is pressed the radio itself turns off, but the clock is still illuminated. Turning the clock off using the clock button doesn’t stop the power drain as the battery is dead if it sits too long (overnight). Normally the accessory socket (12v cigarette lighter socket) will not work with the key removed but now it does.
I have done a little research and have not been able to get a clear answer.
All the fuses are seemingly good... but I didn’t think it would be a fuse since I figured they would STOP the power flow.
Any ideas on where to start and how to diagnose?
TIA!
TIA!
