-   -   Any reason why my keys won’t open the driver door? (https://www.nissanversaforums.com/general-technical-electrical/42964-any-reason-why-my-keys-won%E2%80%99t-open-driver-door.html)
tomf1963 05-23-2019 12:48 PM
I have a 2007 Versa. Recently my keys no longer open the driver’s door. I can still use the remote door opener to unlock the door. Any thoughts on what’s the issue?
Ecate 05-23-2019 01:01 PM
Originally Posted by tomf1963 (Post 288600)
I have a 2007 Versa. Recently my keys no longer open the driverís door. I can still use the remote door opener to unlock the door. Any thoughts on whatís the issue?
if you can start the car fine I would say that the problem is not in the key.
Have you tried your second key? same thing?
Can you lock the door using the key? or it doesn't work all around?
I always use some graphite grease twice a year to keep the mechanism smooth...maybe it got jammed over time.
Alfresco 05-23-2019 08:58 PM
Just went through this with a 2003 Ford Ranger. Shot a lot of WD-40 into the lock; end of problem...
amc49 05-23-2019 10:14 PM
That can do it. Anything beginning with lock cylinder and stretching all the way down to the linkage hookup at the latch assembly can be at fault there. Often can be a broken link, many different ways used to attach the linkage parts together and most of them are plastic parts that cost 50X what they are worth other than you gotta have them.
Central Coast 05-29-2019 05:16 AM
I have a 2015 Versa Note and I noticed the same thing. I tried my other new key and it was fine, so I suspect the key was wearing off. I went ahead and made another key off of my new key. Problem solved.
amc49 05-30-2019 03:02 AM
A lot of people begin to use the remote all the time and do not ever use keys then the lock cylinder corrodes in place. Best to at least 3-4 times a year use the keys to open doors to keep the cylinders loose and working.
scarecrowdjinn 05-31-2019 05:16 PM
I have a feeling this is a one and done guy. (One post, never to be heard from again)
Anyways,
When you say your key won't open the door, does the key not turn? or does the key turn and just doesn't unlock the door?
