Crank sensor removal - Nissan Versa Forums
  • 1 Post By Alan Laird
post #1 of 6 Old 08-06-2019, 03:07 PM Thread Starter
Alan Laird's Avatar
I have everything disconnected, but for the life of me, I cannot get the sensor removed. I can rotate it, but it will not come out. I have struggled with this for 2 days. Does anyone have the secret to getting this out?
Alan Laird is offline
post #2 of 6 Old 08-06-2019, 04:17 PM
PoMan's Avatar
Quoted: 16 Post(s)
Should be just one bolt to remove, the wire harness of course then the sensor is sealed in the hole by an O-ring, correct? A twisting and pulling action should pop it out. I hear you though. I've had those O-rings really fuse in place due to no lube on it and corrosion. Be it aluminum or iron.
2017 Ram 1500 4x4 pentastar
2016 Nissan Quest SV
2015 Nissan Versa 1.6S
PoMan is offline
post #3 of 6 Old 08-06-2019, 04:28 PM Thread Starter
Alan Laird's Avatar
Yeah, bolt is out, like I said I can rotate it, but no amount of rocking and pulling gets this sensor out!
post #4 of 6 Old 08-06-2019, 05:49 PM
PoMan's Avatar
Quoted: 16 Post(s)
Sounds like it's just rotating within the O-ring groove on the plastic sensor body and the outer surface of the O-ring is fused to the block. The sensor may break in the process, but it will come out. Can you get a pick or flat blade under the bolt flange on it for leverage?
PoMan is offline
post #5 of 6 Old 08-07-2019, 01:06 AM
Quoted: 49 Post(s)
Maybe to spray it with a penetrating oil (like PB Blaster) and let it stay overnight, for oil to work its way between the O-ring and the block.
post #6 of 6 Old 08-07-2019, 03:41 PM Thread Starter
Alan Laird's Avatar
Thanks guys for the responses. Perseverance, a small flat blade screwdriver, a mirror, and I was finally able to get the thing out. Phew, 7 hours.
