Fog and DRL install - Nissan Versa Forums
post #1 of 7 Old 05-18-2012, 01:02 PM Thread Starter
Fog and DRL install
I have a new 2012 1.8S SE (special edition) hatch that does not have fog lights. I haven't checked to see if it is pre-wired for them or not (where would I look, and can it be seen without taking the bumper or anything else off?).
What I'm looking to do is install fog lights, but have them wired as DRL so they are on as soon as I start the car. I know that if I'm pre-wired for fogs, this should be easy, otherwise, it might be fairly expensive. If this isn't an option, are there aftermarket LED kits that would work as DRLs that are good quality and look decent?
Oh, one other thing I was thinking about...adding LEDs on the side mirrors that are connected to the turn signals. Has anyone done this, and if so, where did you source your parts, etc...?
Thanks in advance.
dmolavi is offline
post #2 of 7 Old 05-18-2012, 01:21 PM
JoshG's Avatar
Quoted: 90 Post(s)
Im not 100% sure but it should be prewired for fogs. Wiring should be behind the bumper so you might have to take off.
2010 NISSAN VERSA 1.6
1991 MAZDA B2600i
JoshG is offline
post #3 of 7 Old 05-19-2012, 03:24 AM
You do not have to remove the bumper. You can remove the bottom splash cover located under the bumper or remove the wheel well fender liner or both
sfretwell is offline
post #4 of 7 Old 08-16-2012, 11:38 PM
I am also thinking of fog lamps on an SE. I found these SPYDER® FL-NV2012-C - Clear OEM Fog Lights
The fog lamps on courtesyparts.com has the OEM kit but says it won't fit on an S.
Adam_oh is offline
post #5 of 7 Old 08-17-2012, 02:08 AM
iluvmyVersa08's Avatar
I had asked the same question before about wiring my fogs as DRLs.
Getting my hids installed Saturday. Not sure if I'm going that route anymore though.
iluvmyVersa08 is offline
post #6 of 7 Old 08-17-2012, 03:45 AM
Quoted: 27 Post(s)
Unless you get a different relay kit than the one that comes with the HID's you won't be able to run the DRL's. The stock DRL is just the highbeams running on half the wattage or something like that, and they don't have enough power to turn on the HID's. One will turn on/flicker and one will probably just do nothing, so you will have to pull the DRL fuse.
Drew
2017 Harley Road King Special
ADOversa is offline
post #7 of 7 Old 08-21-2012, 04:17 PM
Oh, one other thing I was thinking about...adding led tubes on the side mirrors that are connected to the turn signals. Has anyone done this, and if so, where did you source your parts, etc...?
Thanks in advance.
I have tried these mirrors with LED lights. They just look beautiful. I will share some pics in next post.
Honyeru is offline
