$5000 fix for 2007 Tiida Q. Help!!! - Nissan Versa Forums
post #1 of 9 Old 11-03-2012, 05:16 AM Thread Starter
Angry $5000 fix for 2007 Tiida Q. Help!!!
Hi there, I own a 2007 Tiida Q (what we call the Versa down here) with only 56000KM on the clock with an MR18DE in it and 2 days ago it crapped itself big time.
Car has always run great since we purchased it new 5 years ago so this big break down was a massive surprise but not as big as the surprise I got later.
Drove to the suprmarket just fine, did my shopping but as I left and started the car it just didn't sound right and the MIL light came on. Also a lot of vibration, most notable in the exhaust pipe. Engine doesn't shake, but the exhaust does and it seriously lost power.
I had just purchased a trolley jack and gasket etc to give it an oil change after I noticed it had developed an oil leak that had started getting worse and was thinking oil pan seal has gone. But this malfunction happened the day after I brought the goods and before I could get do it this weekend. Also thought the valve seals were stuffed, as it has been occasionally blowing a cloud of smoke when started, generally after short trips.
Car now sounds like it is only running on 4 cylinders, and while no smoke, the exhaust smells very fuel rich, like it's not all being burnt. (although I can smell a burning smell inside the car which doesn't smell like fuel or oil.)
Thought I'd just check and if need be change the sparkplugs as I thought a dead spark plug must be the problem. Managed to track down a factory service manual thought weird location for plugs but this will be easy, not realising the plugs are buried deep inside the engine and seem to require a non standard plug socket and that working on these engines is a nightmare compared to any car I've worked on before.
Removed the air intake manifold, and noticed a great deal of oil in it, pipes attached and the air filter. So I though maybe the rings are buggered also.
Removed a coil pack and noticed how deep the plugs are set in, something I must of missed in the manual, not a problem I have extensions, but not a single spark plug socket I own will get in the hole. Manual says 14mm socket, youtube video I watched shows a very slim socket, parts shop says "no such thing as a 14mm spark plug socket"...... So so far unable to check the plugs.
Well a few friends confirmed they think it may be the rings also, so I thought, the engine design I'm not overly familiar with (never had to work on it before outside of general maintenance so had no idea what to expect) I'll get some quotes from a mechanic thinking new set of rings, that should cost much right? well it went from bad to worse, well worse is an understatement.
First Mechanic I rang, He just outright said he refused to go near it, not a job he wants. I thought I misheard him at first.
So I rang another mechanic asking for a quote on replacing rings. He laughed at me. Without saying anything he told me exactly what was wrong with it, Oil in the air intakes/filter, the blowing smoke when stated, oil pissing out of it onto the ground, even the way the car is running and sounds. Said he did one a few months back and it's a complicated engine with a horrible design, requiring too many hours of work for such a simple job as pretty much have to pull everything out and that I'd be looking at about $5000AUD to fix it. Thought he was exaggerating.
So I rang the Car dealer where we got it from's service department. Who outright refused to give me a quote, or a rough idea of how much I'd be looking at, went out of their way to avoid it, telling me I'd have to bring it in, they'd have to "completely" dissasemble it to find out what is wrong before they could quote. I'm not rich, so I needed a good idea of an actual price, not keen on having my car pulled apart then told a price I cannot afford and wonder what will happen to my now apart car when I find I cannot pay.
He eventually said "you will be looking into the thousands" as the engine is complicated and would take probably more than 20 hours labour just for the rings alone, before honing of cylinders etc.
So I'm buggered, no idea what to do as I cannot afford "thousands" especially around 5000, and I'm pretty pissed off too, for a car that is only 5 years old and with only 56000km on the clock such a repair cost is outlandish I feel, especially after paying about $27000 AUD for the thing.
So very long story short, I'm thinking a replacment engine would be shit loads cheaper than getting it fixed, but am having trouble finding a new engine online. (2nd hand ones no probs, but hey after this I don't want to risk a 2nd hand one) So would anyone have an idea of a place to buy a new engine, and the cost I'd be looking at???? I found some on an American site but those were for 2011 Tiida's but advertised at about the 1000USD mark.
Any suggestions of what I need, if the MR18DE's are still available where to get one, a suitable engine of a different model, as I'm thinking a new engine and installation cost is going to be healthier for my finances than getting this one fixed.
What path do people suggest I take?
Thanks in advance.
Doomed is offline
post #2 of 9 Old 11-03-2012, 07:50 AM
APLPIX's Avatar
As far as the engine taking shit goes, swapping the MR20 from the early gen Pulsar is an option other than going for the same MR18, surely there must be salvaged front ends at a wrecker.
APLPIX is offline
post #3 of 9 Old 11-03-2012, 07:54 AM
APLPIX's Avatar
And your username is quite ironic
APLPIX is offline
post #4 of 9 Old 11-03-2012, 02:53 PM
08versailles's Avatar
Quoted: 53 Post(s)
^absolutely, swap motor MR18 or even better MR20. I'm not a wrench and i've never done it, but apparently it's the cheapest and easiest way to go. Use search for mr20 swap etc.
Sorry 'bout the failure, i'm looking forward to an mr20 swap some day
Welcome! 08v
08versailles is offline
post #5 of 9 Old 11-04-2012, 09:49 PM Thread Starter
Okay so MR20? Thanks I'll look it up, and yeah just a very old gamer nick I use everywhere, but yes, also ironic in this case, very much so. lol
Still cannot believe something as simple as rings would cost so much. Shall see how I go and report back if I have any luck. Although this makes me miss my old 72 Datsun 1200.
Remember when they built cars that anyone could fix?
oh and I should of said like it's running on 3 cylinders in the OP.
Doomed is offline
post #6 of 9 Old 11-04-2012, 11:26 PM Thread Starter
Sorry to be a pain, but about how much should I be looking at for either a MR20 or MR18????
Local or foreign prices, I don't mind either. Is it just the block or a complete engine (block and head) Also anything else I should know, like would I have to change anything else like exhaust manifolds for example????
Doomed is offline
post #7 of 9 Old 11-04-2012, 11:44 PM
Super Moderator
sergmx's Avatar
Quoted: 38 Post(s)
I'm not sure about the components, but from what i've seen I'd say it should be around $1,000 at most, i've seen them for about 800 dollars.
Enjoy Life.
2012 Versa HB 6-Speed.
Clean and Simple.
sergmx is offline
post #8 of 9 Old 11-08-2012, 01:55 AM Thread Starter
yeah, I've got a second hand one lined up if need be with about 96,000km on it's clock for about $880, be about $90 for shipping, hoping to get them down on the price.
Contacted the local nissan dealer, and they told me $6900AUD for a new engine, and that that is only for the Block......... (edit: said something about I'll need a new exhaust manifold also if I swap out a MR20, which was a surprise as I was led to believe on the outside they're identical)
Booked in for a diagnostic with my local UltraTune, so I'll see what that says and work out where to go from there. I did find a U.S site a couple of days after the Tiida died, but forgot to bookmark it and now as usual cannot find it lol.
But yeah pretty sure I saw a new engine "complete" for a bit over the $1000USD mark on there. So the pricing I keep getting locally seems to be incredibly over inflated. Guess that's living down under for you.
Doomed is offline
post #9 of 9 Old 11-08-2012, 02:53 AM
hemifan87's Avatar
I have never heard of the mr20 being different at all other then a few parts inside
project Black Widow
https://www.nissanversaforums.com/showthread.php?t=2313
Project 200sx
https://www.nissanversaforums.com/non...w-old-car.html
ΜΟΛΩΝ ΛΑΒΕ
hemifan87 is offline
