Radio deck power and antenna - Nissan Versa Forums
post #1 of 6 Old 01-07-2013, 11:58 AM Thread Starter
Hello all
New to the forum, bought a 2012 versa in October as my winter and daily commuter. Decided to throw in an after market radio so I went online to purchase a wiring harness for the unit. Strangely, the harness said "Subaru" on it, yet it fits the versa, but then Nissan does make a lot of car parts used by almost all major manufacturer, so I am not too surprise
Anyways, after wiring up the unit, I move on to disassmble the dash, and notice that the versa doesn't use a standard antenna plug pin. There is a separate plug, grey color, retengular, which I assume to be the antenna. Upon doing my research, i found wiring adapter for this as well to confirm my assumption, all is good, I figure I can just purchase this adapter
I move on to plug in the after market unit anyways to test it, and notice that it will not power up, at this point, I don't have the antenna plugged in yet. So I went back to the factory deck to see if it will power up, and notice that it will not power up unless the grey, assumed to be antenna plug, is plugged in.
Here is my question, is this really an antenna plug? Or is it some form of weird power plug? If this is a power plug, where is the antenna? I dont want to fry the after market unit by feeding a 12v feed to the antenna jack (Assuming the grey plug is live)
I am sure my wiring is good, its not that complex.....
Any help will be appreciated..
Thanks
/G
godwine is offline
post #2 of 6 Old 01-07-2013, 04:20 PM
leknaw's Avatar
Antenna
You can use a test light yo see if has power, but I am sure is the antenna. Through the years I have work on cars removing and installing radios, (at home), i have realize that in most of them the antenna plucg/cable also serves as a ground. Hope this jelps, and by the way, there is a plug for the connection to an aftermarket radio.
Originally Posted by godwine View Post
Hello all
Thanks
/G
Blck2010 1.8
leknaw is offline
post #3 of 6 Old 01-07-2013, 04:25 PM Thread Starter
Thanks Leknaw, I didn't know the antenna ground would serve as an overall ground, i will get the adapter and give it a shot. Didn't have this issue with my other cars
godwine is offline
post #4 of 6 Old 01-08-2013, 02:04 AM
NewNissanNupson's Avatar
If you have the sedan my Pioneer worked without the antenna plugged in (I found out I needed the adapter the same way you did) but make sure you do ground out the head unit to a bare piece of metal in the back, also that the fuse on the back of the head unit is pushed in, I found this to be the problem when doing my brothers head unit.
NewNissanNupson is offline
post #5 of 6 Old 01-08-2013, 10:05 AM Thread Starter
Hi, mine is a hatch. I will order the adapter online and try it out. Fuse seems to be good
Should I order ones with the blue cable for power antenna? On my 911, I had similar config, a blue wire , but antenna is part of the windshield. I later on discovered that the antenna is "active", so it requires a signal from the deck to be turn on. Without this, I was gettin poor fm and almost no am
Is the versa the same? As in, the active antenna thing that need the blue wire for the radio to turn it on?
godwine is offline
post #6 of 6 Old 01-09-2013, 08:00 PM
That I'm not sure about, the only one I found to order had the blue wire so I'm guessing yes you will need it.
