wiper sub light - Nissan Versa Forums
post #1 of 5 Old 02-04-2013, 09:50 PM Thread Starter
Angry wiper sub light
Hi everybody I have small problems with my versa 2009 sl. My front wiper stall in the middle of the windows and re start after 20 second at any setting position. My subwoofer dont play in the trunk and trunk light dont turn on. On the radio, subwoofer is on and all fuses of the car are good. Can you help me please ????
fairladyz is offline
post #2 of 5 Old 02-05-2013, 01:47 PM
alonsorules8's Avatar
The wiper issued most likely is a faulty pulse board. as for the sub woofer and trunk light check under the hood for additional fuses that my run the sub. If it is not that the only 2 other options are a faulty bcm or an electrical gremlin.
alonsorules8 is offline
post #3 of 5 Old 02-09-2013, 02:17 PM Thread Starter
I found all trouble shooting and schematic on pdf for versa from axel to lamps change.
Its like the trouble shooting dealer book. If someone want to have all pdf page just ask me theres about 1000 page in pdf
You can do test with consult 3 obd2 and if you dont have consult 3 they show you how to do it the other ways
EXemple
< SERVICE INFORMATION >
FRONT WIPER AND WASHER SYSTEM
Terminal and Reference Value for BCM INFOID:0000000004306909
Refer to BCS-11, "Terminal and Reference Value for BCM" .
Terminal and Reference Value for IPDM E/R INFOID:0000000004306910
Refer to PG-24, "Terminal and Reference Value for IPDM E/R" .
How to Proceed with Trouble Diagnosis INFOID:0000000004306911
1. Confirm symptoms and customer complaint.
2. Understand operation description and function description. Refer to WW-3, "System Description" .
3. Perform preliminary check. Refer to WW-10, "Preliminary Check" .
4. Check symptom and repair or replace malfunctioning parts.
5. Does front wiper and washer operate normally? If YES, GO TO 6. If NO, GO TO 4.
6. Inspection End.
Preliminary Check INFOID:0000000004306912
CHECK POWER SUPPLY AND GROUND CIRCUIT FOR BCM
Refer to BCS-15, "BCM Power Supply and Ground Circuit Inspection"
CONSULT-III Function (BCM) INFOID:0000000004306913
CONSULT-III can display each diagnostic item using the diagnostic test modes shown following.
WORK SUPPORT
Display Item List
DATA MONITOR
Display Item List
BCM diagnosis position Diagnosis mode Description
WIPER
WORK SUPPORT Changes the setting for each function.
DATA MONITOR Displays BCM input data in real time.
ACTIVE TEST Device operation can be checked by applying a drive signal to device.
BCM
SELF-DIAG RESULTS BCM performs self-diagnosis of CAN communication.
CAN DIAG SUPPORT MNTR The result of transmit/receive diagnosis of CAN communication can be read.
Item Description CONSULT-III Factory setting
WIPER SPEED
SETTING Vehicle speed sensing type wiper control mode can be changed in this mode.
ON
OFF —
ALL SIGNALS Monitors all the signals.
SELECTION FROM MENU Selects items and monitor them.
Monitor item Contents
IGN ON SW “ON/OFF” Displays “ignition switch ON (ON)/Other OFF or ACC (OFF)” status as judged from ignition
switch signal.
IGN SW CAN “ON/OFF” Displays “ignition switch ON (ON)/Other OFF or ACC (OFF)” status as judged from CAN communication
signal.
FR WIPER
post #4 of 5 Old 02-11-2013, 10:49 PM
mrb
AUTO STOP OPERATION
With wiper switch turned OFF, wiper motor will continue to operate until wiper arms reach windshield base.
When the wiper arms are not located at base of windshield with wiper switch OFF,
ground is supplied
• from IPDM E/R terminal 33
• to front wiper motor terminal 3, in order to continue wiper motor operation at low speed.
When the wiper arms reach base of windshield, front wiper motor terminals 4 and 2 are connected, and
ground is supplied
• to IPDM E/R terminal 38
• through front wiper motor terminals 4 and 2, and
• through grounds E15 and E24.
Then the IPDM E/R sends auto stop operation signal to BCM with CAN communication line.
When the BCM receives auto-stop operation signal, BCM sends wiper stop signal to IPDM E/R with CAN communication line.
IPDM E/R stops wiper motor. Wiper motor will then stop wiper arms at the STOP position.
Review the powerground E15 and see the correct signal on pin 4 of wiper motor assy
GND final stop position
12V move position
mrb is offline
post #5 of 5 Old 08-25-2014, 01:47 AM
If it's still possible to get that pdf for trouble shooting I would be grateful.
Dave Schaaf is offline
